D2M is not a good part number. Should be one of these with part number cast into the side of the link. Add one number to the link part number to make LH and RH links.
Thanks Magnet!! that info will help very much
6B 4645 found it. would this be for an early set of links?
The 6b4645 is a link for hurley track d4
what is "hurley track D4" is this an aftermarket track supplier?
my links new were 3 34/64 rail height new and the rebuild limit is 3 1/4 the throw away is 3 1/8 inches. my actual height is 3 7/16 with 1 inch left on the track adjusters on the first wear cycle before a pin and bushing turn. tractor shows aprox 4300 hours on meter. should be good for how many hours??? guess?? just for fun:wof:
