help identifying hydraulic pump
Showing 1 to 6 of 6 results
helifixer
Send a private message to helifixer
I need help identifying this hydraulic pump, it is on a D69U s/n 25753.
it is pouring oil out the shaft and over filling the transmission. in about 2 hours it is spitting oil out of the dip stick for the transmission.
if I can figure out what it is i will than need at least a parts book to figure out what is wrong
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5786.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5785.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5784.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5783.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5782.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5781.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5780.jpg[/img]
[img]http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP5779.jpg[/img]
Wed, Mar 31, 2010 9:42 AM
I sure want to say it is a BeGe pump.....but it doesn't look like the style I'm familiar with....also BeGe was pretty good about having their name and serial/model numbers stamped on their units.
Problem is there is very little information available on BeGe pumps and equipment.
May be a later model when the company fell into the hands of Oliver.
In any event they are a pretty simple build and your leak source is most likely an internal drive shaft seal.
Wed, Mar 31, 2010 10:08 AM
helifixer
my first thought was that it looked like a begee pump but all I have ever worked on had their name cast in every piece.
Wed, Mar 31, 2010 10:11 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to helifixer:
Hey OM, sorry it's taking so long to get those copy's to you just bought scanner and I'm trying to set it up with my note book should have them to ya by the end of the week.
Ya that is a bee gee pump we have two of them they are relible high psi and gpm they have a aluminum tag that's why you can't find any markings.
Wed, Mar 31, 2010 1:39 PM
helifixer
Reply to Rd6 plower:
ok I found the rivets where there was a tag, but no tag.
anyone have a parts break down?
Wed, Mar 31, 2010 7:50 PM
Reply to helifixer:
These folks have almost everything related to hydraulics and seals.
http://www.bulldogkits.com/
just have to measure up what you have and look it up.
Wed, Mar 31, 2010 8:43 PM
Rd6 plower,
Thanks for the update...looking forward to getting the info😊
Wed, Mar 31, 2010 10:29 PM
