Help identifying grader
Showing 1 to 10 of 15 results
Harneymaki
Send a private message to Harneymaki
https://minneapolis.craigslist.org/hnp/grd/6034404446.html
Can anyone I.D. this grader? Looks interesting.
Wed, Mar 8, 2017 7:24 PM
Thank you received: 34
Hi, Folks.
I have my suspicions, one of which is that it might be missing an engine. Dunno why I would think that, unless it's that control box with all the levers sticking out of it. Another suspicion is that it might just possibly be a Cat.
Wed, Mar 8, 2017 9:09 PM
STEPHEN
Hi, Folks.
It's cheap enough, buy it!
Wed, Mar 8, 2017 9:10 PM
Skinner
Reply to STEPHEN:
Adams leaning wheel looks like it has a power unit to run the controls
Wed, Mar 8, 2017 9:46 PM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to Skinner:
Could it simply be a PTO drive off of the pulling tractor?
Thu, Mar 9, 2017 2:26 AM
Dieselholic92
Thank you received: 8
Reply to Walt D7-3T:
It looks to me like it should have the small Caterpillar power unit on it. If you look from the rear, there looks to be a small gas tank on the left side of the controls, but not sure where the engine is?
David Gruhot
D & G Excavating, Inc.
Thu, Mar 9, 2017 2:46 AM
chriscokid
Yes, i would agree that is is a Adams.
Thu, Mar 9, 2017 2:48 AM
mog5858
Reply to chriscokid:
that very nice and for the price. if we where not digging out after a 2 day blizzard i would be on the road that way lol. it is powered but a PTO as you can see up front on the neck so i would say the towing cat would need PTO as well.
Thu, Mar 9, 2017 6:37 AM
Masic
Send a private message to Masic
Reply to mog5858:
Definitely a pull type non PTO assist. The upper draw bar does have a hand controlled gearbox for front wheel lean.
The majority of the controls are set and forget hand crank and the pull leavers could be the on the fly controls for the large gearbox which looks to be ground driven as seen in the second last photo right side through a 90deg drive to the rear axle but this is the shaft for the leaning wheel aspect of this vintage machine. The hand crank at the centre of the rear drive box means it's human powered. You can retrofit this grader to be hydraulic motor assist be adding a coupler/mount/hyd motor to this hand crank. Motorless for sure. Look up
Adams 125 Leaning Wheel, Pull Type Grader
or...... added to remove the theory of PTO drive
Looking at the main backbone frame of the unit, it Most likely not be, PTO driven from prime mover to rear gearbox. The drive system would be a straight shaft from PTO to an under slung drive shaft from the draw bar on this grader, to a double 90 degree drive in the front axle neck to a short driveshaft inside of the tapered part of the backbone frame supported by a hanger bearing to a longer straight driveshaft in the main part of the backbone into the rear drive gearbox which would output to control levers for shift in/out control and then to the 90degree drive (as seen in second last photo bottom right side of gearbox) to the rear wheels for assisted mechanical rear wheel drive (taking a breath) sounds possible but Way Way Way over engineered and complicated for its time. Or it's a pull type with manual crank controls, lever controls are human powered as seen in the photo. Nice piece of military history
Interesting for sure and would make for an epic lawn ornament all restored or work her instead of a box scraper
Thu, Mar 9, 2017 7:04 AM
CarlsCAT
Send a private message to CarlsCAT
Reply to Masic:
Most likely an Adams Leaning Wheel Pull Grader...They had a 5hp Wisconsin engine to power a hydraulic pump for the controls...
It appears to be larger than the Adams 134...all manual...with rubber tires...that I have...
A few years ago, there was one of these down here in Texas...Someone bought it for yard art...
It is well worth the asking price...Don't let it go...It's a rare piece of equipment...
Respy, CarlsCat...
Thu, Mar 9, 2017 7:30 AM
Harneymaki
Reply to CarlsCAT:
Respy, CarlsCat...
Wow! That's so much more info than I ever dreamed of! This forum is awesome. Thanks!
Thu, Mar 9, 2017 7:43 AM
