Help Identify Belt Pulley
YeLLoIrOn
Send a private message to YeLLoIrOn
The housing part # 1A-1122. Its pretty good size. Rockwood pulley. I think it fits a gas seventy.? It wont fit the sixty or the diesel fifty so you can count those out.
Caleb
Mon, Jan 25, 2010 6:43 AM
josh
Thank you received: 14
That is a correct part number for the seventy belt pulley case.
Mon, Jan 25, 2010 10:37 AM
ag-mike
Reply to josh:
the gear box maybe cat but the pulley sounds like a replacement. i have rockwoods that fit d4's and d2's. someone may wanted different size that was available from cat. good luck.
Mon, Jan 25, 2010 9:40 PM
dick
Send a private message to dick
Reply to josh:
That belt pulley will also fit D75 and all of the D8s through 15A. My books don't list a belt pulley for 35A, 36A, 46A.
Mon, Jan 25, 2010 9:51 PM
YeLLoIrOn
Reply to dick:
appriciate the info guys. did a little more research on my own- rockwood pulley was the earlier version G70 and diesel series. the D8's had a steel pulley.😊
Tue, Jan 26, 2010 7:50 AM
