Help Identify
Help Identify
Showing 1 to 6 of 6 results
DesertGaucho
Send a private message to DesertGaucho
Just bought a dozer tractor# 9G 35 72 Sp or 96 35 72 SP
Any help in locating info and manuals on it will be much appreciated.
Runs like a charm. Located in Phoenix,Az.
Thank you very much!
Sun, Jul 1, 2007 1:36 AM
David Wills Cat 60
DG,
9G series is an early D7, dating from the mid 1930's through to 1940. Someone on the BB should be able to provide an approx. year of manufacture.
Ebay would be my recommendation, although you may have to wait for one to be listed, as the earlier manuals are more difficult to find.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
Sun, Jul 1, 2007 4:23 AM
84WD10
Send a private message to 84WD10
Reply to David Wills Cat 60:
DG,
Hello DesertGaucho,
The tractor in question is definately an early "D7", these tractors were built from 1935 and discontinued in 1940. Total No built = 7,254.
Your tractor Serial No 9G 3572 was built during the 1937 production year., and were superceded by the "D7" 7M series tractors during the 1940 production year.
Regards
Alan T.Lewis
Christchurch
NEW ZEALAND
Sun, Jul 1, 2007 5:25 AM
catalac
Send a private message to catalac
Reply to 84WD10:
Hello DesertGaucho,
Regards
Alan T.Lewis
Christchurch
NEW ZEALAND
DG,
The ACMOC Serial Number Reference Manual indicates that the tractor could be either a late RD7 or an early D7. The first serial number built in 1937 was 9G2507 and the last 9G4348. The first serial number was an RD7 and the last a D7. The effective serial number of the change over is not known or wasn't at the time the book was printed. Someone on here can help with the difference between the two models to assist with positive identification of your tractor model.
Regards,
Lee
Lee Sorbel-ACMOC Past President
Sun, Jul 1, 2007 8:23 AM
David Wills Cat 60
Reply to catalac:
DG,
Regards,
Lee
DG,
Does it say D7 or RD7 on the front of the radiator?
Can you post a picture of the tractor?
1948 D6 9U
1963 D6B 44A
1970 951A 63K
Sun, Jul 1, 2007 9:57 PM
catalac
DG,
David,
Do you know if there were actual changes to the tractor or simply a model number change? My not so dependable memory 😕 is telling me this was simply a dropping of the R in the model number.
Regards,
Lee
Mon, Jul 2, 2007 1:52 AM
Thank you received: 60
Reply to catalac:
David,
Regards,
Lee
Hi catalac,
I have the parts book for the 9G1 - 9G2875.
From what I see there were fairly constant changes (typical Cat) but I don't see anything that would indicate specific changes with the RD7 to D7 model.
Interesting to note there was a radiator change, including top tank @ 9G2778 but the illustration does not indicate if the RD7 raised lettering was involved.
Mon, Jul 2, 2007 7:55 AM
| Kingaroy, Queensland
