Help I mis placed my Manual D4 Coolant
OCB
Send a private message to OCB
Went to look into my Manual D4 to see how much Anti freeze to put in but that Manual is missing. How many gallons of coolant does a D4 5T hold? My guess is 10 gallons.
Also isn't there a bleed plug/valve on the pony for bleeding air?
Thanks Clay
Mon, Dec 1, 2008 8:51 AM
11 gallons is what's spec'd but that's not what they will hold.The 10 gallons+ is more like it.
Yes, there should be a vent valve on the pony manifold for air bleeding........but I have seen at least one that didn't have one🙄
Mon, Dec 1, 2008 9:15 AM
OCB
As I looked for my manual I run across a Holt 75 manual and did some reading. It didn't memtion Capacity but just said fill it up, interesting how described things 90 years ago including the assembly of the radiator.
Mon, Dec 1, 2008 8:29 PM
