Help, How do I add a pic.
Showing 1 to 9 of 9 results
cojhl2
OK, I give up!! I have been on this terminal now for two solid days taking only time off for meals and I cannot find out how to upload new pics.
I have done searches but it seems like I don't have the pointers mentioned in the FAQs.
Apparently I need a step by step instruction to follow.
Sat, Jul 28, 2018 1:49 AM
Walt D7-3T
Send a private message to Walt D7-3T
Take a look at the post that §wishy made about 4 years ago. It is in the BULLETIN BOARD OPERATIONS forum.
http://www.acmoc.org/bb/showthread.php?288-How-to-Post-Pictures-on-the-BB
Sat, Jul 28, 2018 2:29 AM
Machias cat
Send a private message to Machias cat
Reply to Walt D7-3T:
[quote="Walt D7-3T"]Take a look at the post that §wishy made about 4 years ago. It is in the BULLETIN BOARD OPERATIONS forum.
http://www.acmoc.org/bb/showthread.php?288-How-to-Post-Pictures-on-the-BB[/quote]
Four years ago? Howabout 11 years ago.
And a quote from post #5 (posted in 2012) of the noted conversation.....
"Unfortunately, Swishy's advice is dated 2007, so it does not apply. Both ACMOC and the ACME forums have entirely different software now."
So how does one post pictures on this site? I have hacked my way through it but really don't know how it works to possibly be expert enough to give advice / training.....
Anybody willing to show the way?
Sat, Jul 28, 2018 5:27 AM
Thank you received: 77
Reply to Machias cat:
This is how I do it, but there's probably other approaches.
I post pictures to threads, so I open a new thread or reply to an existing one. I write my text and then when I want a picture to follow my text, I then click on the paper clip attachment icon above. If you hover your mouse above it, then a small popup says "Attachments". Click on that button. A new window opens. Click the "Add Files" button in the top right corner. Another popup opens - "Choose file" - select your file from your pc. If you want to add more pictures (up to five in one upload session), then click the plus sign and select more pictures.
Then, click Upload. The files will upload and automatically populate into the lower panel and the Insert Inline button will activate showing the number of pictures it will add. Those pictures will be selected in that panel so you can tell which ones are going to be inserted into your thread. Once they have been inserted, the button will clear and you can push Done.
You will then return to the thread editing window. A good practice is to add a blank line between each attachment link (looks like a couple of brackets with a number in between) - make sure that you insert the blank line between the closing bracket of one attachment and the opening bracket of the next attachment e.g.
[*ATTACH=CONFIG]77309[/ATTACH]
[*ATTACH=CONFIG]77310[/ATTACH]
(I added an asterix to prevent it actually inserting a picture).
Then hit preview, if it all looks good then hit submit (ah, it inserted the dang picture anyway....)
Sat, Jul 28, 2018 5:48 AM
cojhl2
I also found Swishey's info of no use. And where I do see results of "Help" it seems they point to click points to which I don't have.
I have posted pics before and did not find it this complicated as I could finally figure it out. But not this time!!😕
Sat, Jul 28, 2018 5:49 AM
Reply to cojhl2:
on the reply page I scroll down to the upload photos link and then pretty much follow Neil's procedure
Sat, Jul 28, 2018 5:59 AM
Walt D7-3T
Reply to dpendzic:
OK, guys, so it seems that I cannot read. Actually I was not paying attention and I actually have not idea were I got the " 4 years" from. So all I can say is OOPS!
My most humble apologies.....
Sat, Jul 28, 2018 10:11 AM
Machias cat
[quote="Walt D7-3T"]OK, guys, so it seems that I cannot read. Actually I was not paying attention and I actually have not idea were I got the " 4 years" from. So all I can say is OOPS!
My most humble apologies.....[/quote]
No worries, Walt. Just a little gentle ribbing. We all lose track of time.
Sat, Jul 28, 2018 10:19 AM
cojhl2
Thank you Neil and dpendzic. I dont have time right now but later I will get back toit and follow your instructions.
Sat, Jul 28, 2018 7:48 PM
Oil Slick
Reply to cojhl2:
Are you trying to post a screenshot (you push top and bottom button on your phone or tablet and it takes a picture of the screen)? I’ve tried and tried but it won’t let me post a screenshot. Only will let me post a picture. No idea why since screenshots and pictures are all in the same photo file.
Sat, Jul 28, 2018 8:11 PM
