Help
conmanklh
Send a private message to conmanklh
I have a D4 Caterpillar 7U crawler tractor that I was trying to clear water out of the radiator for winter storage. I have flushed the rad 3 times now and I keep getting oil coming from the drain plug. It also has a slobbering issue, a lot of oil is coming out the exhaust pipe. I was wondering if anyone out there might have seen this before, of have an idea what I can do to repair the problem.
Wed, Sep 30, 2015 5:31 AM
Dandy Dave
Send a private message to Dandy Dave
Sounds like an oil cooler/heat exchanger leak. Dandy Dave!
Wed, Sep 30, 2015 5:55 AM
old-iron-habit
Most of the time slobbering out the exhaust comes from not being run at the correct temperature and not being worked hard enough. Before you commit to a tear down hook up a good load to it and run the hell out of it for a few hours. My D2 was slobbering when I got it and after hooking to a 14 ft disc and running in 2nd gear in heavy soil for 4 hours it burnt the oul out of the pipe and now runs like it should. Hook up enough to make it work hard.
Wed, Sep 30, 2015 7:23 AM
I am a firm believer in adding antifreeze and keeping the cooling system full--otherwise air gets in and rusts whatever metal it can
Wed, Sep 30, 2015 7:31 AM
Thank you received: 19
Reply to dpendzic:
Remove the exhaust manifold and check if all ports are oily or is it just one. The oil cooler is an air/oil unit. It is not connected to the radiator. It just sits there as a separate unit using the air stream. If it leaks oil the leak will be external.
Wed, Sep 30, 2015 8:25 AM
