Heat plugs in pistons do ???
What does a heat plug do in those pistons that have them? Initiate fuel burn? cool piston? protect the hottest spot on the surface?
Wed, Mar 11, 2009 4:26 AM
My understanding is that they were a heat transfer and anti erosion device to deal with the high velocity, high temperature combustion gases being discharged from the pre-combustion chambers. The plugs are located directly under the pre-com "target" and were an aid to avoiding burning holes in piston tops.
Wed, Mar 11, 2009 7:36 AM
Thanks! So obviously not seen on pistons of modern engines.
Wed, Mar 11, 2009 8:55 AM
Here is a picture of the "plug" in a D8H piston.....material in this case is stainless steel.
Wed, Mar 11, 2009 10:36 AM
