Heat Houser d8h
Heat Houser d8h
Showing 1 to 7 of 7 results
dph
Send a private message to dph
Does anyone know where to get a heat Houser for an old caterpillar d8 at? I know there's a company called Birch manufacturing out of Fort Dodge but I've had no luck and getting them to call me back. Is there another source out there for these old caterpillars?
Wed, Nov 15, 2017 8:42 PM
TimT
Send a private message to TimT
On the 583's 8H,s 9's... We used to have a set of good tarps with twist tabs on the hood and grommets on the tarps. They went on the hood sides over the engine "Side curtains" ... then we made up some rods that inserted to the canopy posts around the operators area and hooked up a tarp around the seat area with bungee cords... all those machines had reversible fans... I can tell you that it could be dam cold "like 15f and on the open station 583's you could run them wearing a short sleeved shirt...If you were working them.. When it got relay cold we would set the brakes,put the transmission "powershift" in 3rd gear and crack the throttle a little... the heat from the floorboards would warm you right up nice and toasty... and we never had any transmission trouble. we never left then in gear for too long though.. But the heat would be great... the cabbed machine had no heaters and we did the same thing on them. I never froze on any of those machines. Some pics that show the "Winter Curtains" look close..... cheap and homemade.
[attachment=45586]no 4.jpg[/attachment]
[attachment=45587]Berwick 4.jpg[/attachment]
[attachment=45588]Berwick 1.jpg[/attachment]
[attachment=45589]83.jpg[/attachment]
Thu, Nov 16, 2017 12:18 AM
old-iron-habit
Reply to TimT:
[QUOTE=TimT;196515]On the 583's 8H,s 9's... We used to have a set of good tarps with twist tabs on the hood and grommets on the tarps. They went on the hood sides over the engine "Side curtains" ... then we made up some rods that inserted to the canopy posts around the operators area and hooked up a tarp around the seat area with bungee cords... all those machines had reversible fans... I can tell you that it could be dam cold "like 15f and on the open station 583's you could run them wearing a short sleeved shirt...If you were working them.. When it got relay cold we would set the brakes,put the transmission "powershift" in 3rd gear and crack the throttle a little... the heat from the floorboards would warm you right up nice and toasty... and we never had any transmission trouble. we never left then in gear for too long though.. But the heat would be great... the cabbed machine had no heaters and we did the same thing on them. I never froze on any of those machines. Some pics that show the "Winter Curtains" look close..... cheap and homemade.
Interesting on how you warmed the floor boards. My Ranger log skidder with a Clark power shift transmission states in the operators manual for cold weather warm up. Set parking brake, place transmission in third gear, set throttle at 1/3 to 1/2 speed to apply reasonable torque convertor load, and let run until normal operating temperature is reached.
Thu, Nov 16, 2017 12:42 AM
Reply to TimT:
Heres some from some winter jobs. D7 in 78 blizzard, D4 couple years ago.
Thu, Nov 16, 2017 12:47 AM
razz
Send a private message to razz
I mite have one don't know whats left cleaned shop a year ago don't know if brackets are there. look today Mark
Fri, Nov 17, 2017 7:10 PM
kracked1
Reply to razz:
A couple cheap 8x8 tarps and a roll of fence wire will make it as warm as you will ever need. Cover exhaust manifold side first as you will get the most heat from that side. If you need shelter from the wind, saran wrap around the roll cage will work in a pinch. Tarp both sides and you will be toasty warm while working her.
Sat, Nov 18, 2017 7:55 AM
dph
Reply to kracked1:
I purchased a couple of tarps, but I did get a hold of Burch. I needed to order it through Ziegler.
Sat, Nov 18, 2017 9:21 PM
razz
Reply to dph:
I looked all brackets are gone Mark
Sun, Nov 19, 2017 1:22 AM
