Head Gasket Replacement
Showing 1 to 7 of 7 results
chruska
Send a private message to chruska
I'm looking for some advice on replacing the head gasket on my Cat d2 5U. I haven't received the gasket yet. But here's the catch.
I replaced the head gasket once already when I rebuilt the engine. The head got planed and totally re-built. once I had everything tightened down I noticed diesel coming past the head gasket once
the engine had warmed up. It was also miss firing on cylinder one (which I believe to be a damaged injection pump/plunger). I ordered another head gasket and I need some advice on how to prepare the surfaces and
if I should accompany the head gasket with a sealing angent. I should note that I was not present when the first head gasket was put on. I have the torque specs.
Tue, Apr 15, 2014 3:50 AM
restore49
Be sure to check the liner projection is within specifications. Bob
Tue, Apr 15, 2014 5:15 AM
DPete
Reply to restore49:
Clean the block with emery cloth, need to get all the carbon off. Make sure the nozzles are good and they are tight, kind of sounds like the # 1 may be bad and over fueling. I would go with Cat nozzles, I had a set of aftermarket and the tractor ran poorly, put in a set of Cat, the difference was night and day.
1962 D4C
Tue, Apr 15, 2014 7:49 AM
sandcreek
Send a private message to sandcreek
Reply to DPete:
Run a die over the threads on the studs and sure the nuts are good. I use a die grinder with roloc abrasive disks to clean gasket surfaces. I also use copper spray on sealant. I buy it at the local auto parts store. It makes the gasket sticky to help seal it.
Tue, Apr 15, 2014 8:08 AM
Thank you received: 52
Reply to sandcreek:
Use this sealer, both sides of gasket.
Tue, Apr 15, 2014 8:48 AM
restore49
I used the 300 Permatex - first couple of start cool down (after re-torque head) had some seepage - it cleared up after a few more cycles. The 300 does not get hard and continues to seal? Bob
Wed, Apr 16, 2014 5:50 AM
DPete
Reply to restore49:
Guess I'm the black sheep, put mine on dry, no leaks so far. We'll give her a good workout in Tulare and see what happens
1962 D4C
Wed, Apr 16, 2014 9:05 PM
AJ.
Send a private message to AJ.
Reply to DPete:
That sounds like the head is not pinching the gasket,how much has been planed off it,is there dowels? could the holes be too shallow,is all the carbon cleaned from around the studs where they go in the block,if the head is not seating right you will have an over heating issue if compression gets to the coolant so the liner protrusion need to be correct,neat fuel going into the cylinder will wash off the oil and you will have a seizure.
Good luck
AJ
Fri, Apr 18, 2014 4:52 PM
