Head gasket job
Head gasket job
Showing 1 to 10 of 11 results
Julian
Send a private message to Julian
Evening all.
My D4 7J has a slight issue with the head gasket, when it's warmed up it leaks a small amount of oil and coolant down the left side.
The engine is great, no oil in the water, no water in the oil, 4 good compressions and no exhaust smoke except for a bit of black when under full load.
I have found a new old stock copper sandwich gasket, (which I think is correct for the job but not too sure) and was thinking of doing the job.
But I was reading around the subject area and it appears the engine has cylinder liners (wet liners?) and I would create a shed load of work if the bottom water seals went. Also is it doable to remove the head without pulling the pony motor as that would make the job much harder?
Cheers Julian.
D47J5052
Sun, Sep 3, 2017 2:09 AM
JoeG
Send a private message to JoeG
It can be done without removing the pony, the gasket that goes between the pony and the head is the toughest part to get right. It has been a while since I did a 4400 head but I remember sliding that gasket in after the head was down but not torqued, I think we pried the gap open and slid the gasket in, it was lubed up with RTV and it has a metal frame in it to keep it "shaped up" during this process.
I just finished the head on my D6 9U and I used aviation permatex type gasket sealant. It now has no leaks, previous it had the same symptoms you describe. The sealant is the easiest I've ever applied yet also the sloppiest of stuff, but it works. I use it on all major assemblies and can't complain about leaks once it cures.
Sun, Sep 3, 2017 2:15 AM
Julian
Reply to JoeG:
Thanks Joe, that's given me encouragment, looks like I'll have try and get a new pony to main engine gasket.
What about the liners, is the 6 cylinder the same set-up as the 4 cylinder?
Julian
D47J5052
Sun, Sep 3, 2017 3:05 AM
Yes all the CAT engines with the exception of the 3204/3208 have wet sleeves. It is not likely you would HAVE to disturb the sleeves changing the head gasket. They are usually stuck in the block pretty good!
On the other hand it is common to have seeps along the head gasket line that are only an unsightly mess, never causing any problem.
**********If you take the head off you need to tell yourself "my engine runs well and absolutely does not need an overhaul" about every thirty seconds until you have it buttoned up again! Above all, do not feel the cylinder bores......better yet don't look at them either! It is a slippery slope that starts with the head coming off for something minor and leads directly to a complete overhaul!********
Sun, Sep 3, 2017 3:56 AM
Mike Meyer
Thank you received: 6
Julian, it is not unusual for older head gaskets to need re-torqueing and it can be done without removing the head, my RD4 had those symptoms you describe and it was a simple matter of slightly undoing each head nut about 1/8 of a turn then re-torqueing them to the correct spec, try that first before pulling the head off.
With the help of "Eddie" we refitted a reconditioned head on to my D4 7J diesel motor with the pilot motor in place, it can be done but it is a very tight fit.
Try re-torqueing the old head gasket first.
Mike
Sun, Sep 3, 2017 4:10 AM
gauntjoh
Librarian
Thank you received: 5
Reply to Mike Meyer:
Mike
Hey Julian, I just notices you are in Warrington, UK. I have just arrived home from Tom Atherton's working event today and wondered if you were there, if so it's a shame we missed each other.
My D7 7M also has a very slight weep of oil from the front cylinder head gasket which appears to do no harm, so as CCjersey says maybe best to leave well alone.
Sun, Sep 3, 2017 4:13 AM
Reply to gauntjoh:
My D2 gasket weeped really good till I retorqued also. Taking the head off as others have said doesn't require anything else to be disturbed except for loosening the pony so you can apply a slight tension to slip the new rubber gasket down in there. Like Mike explained, Someone a long time ago suggested sandwiching it between two thin metal plates, then slipping it into position, sliding each plate out, one at a time.
(loosening and wedging the pony away worked for me)
I believe I lubed it with RTV to assist sliding the plates out on the theory that it would help it seal if I deformed it.
Sun, Sep 3, 2017 6:31 AM
Julian
Reply to drujinin:
Thanks for the replies. Some good advice and I'm going to retorque the bolts first and see what happens, it does make good sense if it saves a lot of work although I rather like doing these sorts of jobs. Anyone have a torque value handy (other than three white knuckles) as my literature is stilll in boxes following a house move?
John, I have moved up north a while ago (Cumbria) I'll update my profile. Glad to hear Tom's do is still going, I though he had jacked it in.
Now then I have an old Fordson water washer tractor with a hell of a noise from the gearbox, another resto job for winter....
Julian
D47J5052
Sun, Sep 3, 2017 4:00 PM
English Al
Send a private message to English Al
Reply to Julian:
Julian
Hi Julian. - torque for head nuts , if it has hardened washers and nuts 1/2" nuts - 70 lb ft -- 5/8 nuts - 140 lb ft. Valve clearance ( hot ) 010" in) Early engines were 58 & 130lb ft Regards Al
Sun, Sep 3, 2017 6:57 PM
Mike Meyer
Reply to English Al:
I thought those specs were in the Technical section, I know "Eddie" has posted them several times, the sheets cover all the Cat engines for torque and sequence.
Mon, Sep 4, 2017 3:40 AM
Julian
Just to close this one up. I took the advice given above and re-torqued all the bolts. I just slackened each one, one at a time and then pulled them up to the given value and quite a few pulled up a fair bit more than previous so I was happy with that. I ran it with the rocker box off and set the clearances and confirmed a good oil supply to the rocker shafts.
The good news is that the leaks appear to be very much reduced. I won't be able to say for sure until I've given it some beans uphill in top and made it sweat a bit but I'm happy so far. As the thing is only a toy I'll live with it for now as the leakage will probably be minimal at worst.
Cheers Julian
D47J5052
Thu, Sep 7, 2017 2:13 AM
| Kingaroy, Queensland
