Having problem removing a D2 pinion assembly from tractor. Need Advise.
daves2035
Send a private message to daves2035
I want to remove the clutch starter pinion assembly from D2 tractor. I removed the pony motor,engaged the pinion lever,tried it both ways. Remove all four bolts,It moves slightly,but is still tight. Looking for advise.Thanks.
Mon, Jun 20, 2011 6:11 AM
SpragueM
It is tough going until you are out about 1/2 inch. There is a large o-Ring that seals off the pinion to housing. It will commonly stick in the bore. Pry evenly around the flange, with discretion, and it should come out.
Matt
Mon, Jun 20, 2011 6:46 AM
ol Grump
Reply to SpragueM:
Matt
Spray it with your favorite loose juice and keep working it back and forth. Just remember, that flange can break if you pry with too much force. Over the years, some rust has formed in the bore the pinion housing is in. Probably some fine dust has gotten in as well plus the rubber O-ring has hardened with age. Keep at it. .it'll come out sooner or later.
Mon, Jun 20, 2011 8:24 PM
Arthropod
Send a private message to Arthropod
Reply to ol Grump:
You will also want to remove the end cover from the pinion. It will bump the governor housing. With the end cover removed from the pinion you have just enough room to slip the pinion out.
Tue, Jun 21, 2011 3:19 AM
daves2035
Reply to Arthropod:
Thanks guys for the help. It now makes sense.
Wed, Jun 22, 2011 7:43 AM
gemdozer
Thank you received: 12
Reply to daves2035:
You need too to removed the screw on inspection plate big motor back the cluch housing for removing and turning the cluch housing
Wed, Jun 22, 2011 5:59 PM
