Hauling Weight !!
Hauling Weight !!
Showing 1 to 6 of 6 results
D6 Pete
Hello ALL ,, we are having a Cat 100 year show in Kingaroy Aussie this weekend coming ,, Could some kind person give me aprox weights for a 8RD8, bare machine ,,A RD7 Wide Bare machine ,, and a Standard gauge Bare RD6..In Tons be great Thankyou .. Regards pete
Tue, Sep 16, 2025 3:05 AM
Thank you received: 227
Pete - no promises this is accurate - From the internet - Google Search - RD-6 (acmoc post) 16,500 lbs, RD-7 25,925 lbs, 8R D8 -- 37,000 lbs - cts
Tue, Sep 16, 2025 3:29 AM
D6 Pete
Will just have to find out in Tons .. 2240 lbs to 1 ton is it !!?.
Tue, Sep 16, 2025 3:46 AM
Pete --2000 pounds per ton (avoirdupois) (US) (called Short Ton)
2240 lbs per Long Ton
Hope that helps. - cts
Tue, Sep 16, 2025 4:47 AM
Thank you received: 140
Hi, D6 Pete.
You'll need to figure that as 2,200 pounds per TONNE. The 'figgers' that cts has given are for the American 'short-changed' short ton and the old imperial long ton.
Tue, Sep 16, 2025 7:55 AM
ChrisE
Thank you received: 41
Hi D6Pete. If you use CTS’s figures and go to online conversion and put the figures in you will convert lbs to any weight you like there is a long list of weights to convert it to.
Wed, Sep 17, 2025 2:59 AM
Hi, D6 Pete.
The bare RD6 would come in at around 7.5 tonnes. The bare RD7 comes in at around 11.784 tonnes. The 8R D8 comes in at around 16.818 tonnes - Australian figures.
Does that help?
Wed, Sep 17, 2025 8:12 AM
