Hardbar pad assembly questions
Showing 1 to 7 of 7 results
Silver
Send a private message to Silver
I am trying to replace the equalizer bar pads and hardware on my D6C 76a. I cleaned up the trough the pads sit in quite well, put in the new pads, put the 'V' shaped plate on top, then put the new housing assembly on top of that. The problem is that the whole assembly will not push down low enough to put on the new carrier roller support assembly. It's like the new rubber pads are too thick? Even when I let the hardbar down with the whole weight of the cat on it the assembly does not go down. I need a good inch to be able to bolt the carrier roller assembly to the track frame. Any suggestions?
Mon, Nov 9, 2015 5:29 AM
Does the "V" shaped plate clear the idler recoil rod?
Mon, Nov 9, 2015 5:48 AM
Silver
Yes, neither this plate (that faces up) nor the rounded housing assembly that faces down with the triangles in it interfere with the recoil rod.
Mon, Nov 9, 2015 6:16 AM
Reply to Silver:
What plate that faces up? I show the equalizer bar resting directly on the curved plate.
Mon, Nov 9, 2015 6:27 AM
Silver
First pieces in are the pads, then on top of the pads is a plate 8M6946 which is like a 'V' with the bottom flattened out. On top of that is the curved plate which the equalizer bar rests upon. It's like the rubber pads are too thick and don't allow the whole assembly so sit low enough in the valley.
Mon, Nov 9, 2015 6:41 AM
Reply to Silver:
Don't know what to tell you. What was your source for parts?
In looking at the 74A parts book the 8M6946 you reference is a 1S2349 plate assem. and they do not interchange. Don't know what the difference is.
Mon, Nov 9, 2015 9:30 AM
Silver
Thanks for having a look OM. I just found a picture of the 1S2349 plate, it looks to be a sharper 'v' shape than the piece I have which is much flatter on the bottom of the 'V'. That may allow the assembly to fit down a little lower. This plate (which I assume is 8M6946 ) is the only piece of this operation that is not brand new so it could be that I need the 1S2349 to fit with the pieces I have.
I guess I just really wanted to know if there was a trick to getting this assembly into place or if I needed to explore my parts options to makes sure all was right. I got these parts from Union Tractor, they are generally very good at getting me what I need.
Mon, Nov 9, 2015 9:41 AM
Reply to Silver:
Good on you! for stopping and having a look. Beats cranking down on the casting ears/bolts until something broke. Shouldn't require any "tricks" for that job.
Mon, Nov 9, 2015 9:51 AM
