hard start D4
hard start D4
bobcatfour
Send a private message to bobcatfour
D47J takes a long time to get going, and usually main motor is warmed up from pony working overtime! After its been running, it will kick right over after being stopped. I thought maybe it was a compression issue? What is the procedure for checking the compression? A friend thinks maybe its an injector problem? How would I conclude if they are the problem? Then what is a fix? There is a metal line that runs from all the injectors, then down and out the bottom of the tractor. This line drip fuel when running! ???
Thanks for any input, Bob
Fri, Feb 29, 2008 11:18 PM
Eric Marshall
Send a private message to Eric Marshall
Bob , How is the fuel pressure while the pony is turning the main engine ?....this will cause hard starting when cold. the metal line is a overflow/bypass
Sat, Mar 1, 2008 9:06 AM
