hard bar
Showing 1 to 10 of 30 results
rustyfender
Send a private message to rustyfender
replacement of main spring with a hard bar. what does that mean?
Wed, Feb 26, 2014 12:44 AM
Thank you received: 47
Means replacing the spring with a ridgid beam, usually a cast or fabricated I-shaped beam with tapered ends. Not recommended if mounted directly to the oil pan such as on D2's and D4's.
Wed, Feb 26, 2014 3:58 AM
rustyfender
Oh sounds rough!
Wed, Feb 26, 2014 5:14 AM
On the contrary.........Dozer is much easier to keep on grade with a hard bar and I have never noticed our D69U riding rougher with the hard bar instead of the spring.
Wed, Feb 26, 2014 7:54 AM
Andrew_D
Send a private message to Andrew_D
My old Allis HD11 has had the spring swapped out for a shop-built bar at some point in its' life. It doesn't match the parts book for a rigid bar. In the parts book, the rigid bar is bolted solid to the track frames and the main frame. This shop-built one uses the original pivots on the track frames and main frame to still allow each track to pivot up and down a certain degree.
How are these suppose to be set up? (Not necessarily AC, but on dozers in general.) Is the main frame and both track frames to be 1 rigid unit? Or are the track frames to be able to pivot up and down (1 goes up, other side goes down)? Or are both designs common?
Andrew
Wed, Feb 26, 2014 8:01 AM
Reply to Andrew_D:
Andrew
Actually the termanology gets misused. The solid equalizer bar (that replaces the spring) is still allowed to oscillate with the track frames. The "hard bar" is more commonly referred to as ridged where the track frames are bolted and oscillation is not allowed such as on tracked loader applications.
Wed, Feb 26, 2014 8:10 AM
old-iron-habit
Thanks OM for so eloquently explaining what I have for long wondered.
Wed, Feb 26, 2014 8:44 AM
Andrew_D
ahhh!! Thanks for the info!
Andrew
Wed, Feb 26, 2014 10:04 AM
mog5858
Reply to Andrew_D:
Andrew
they run hard bar in side boom's too. but the one i have Sean where convention to 572 which make sense that you don't wont stuff moving around when lifting.
Wed, Feb 26, 2014 10:35 AM
MARCOTEN
Reply to mog5858:
aah never knew this about the sidebooms that they are solid made at the equliser bar, any one has pictures of this constuction??
Wed, Feb 26, 2014 4:13 PM
Online
Thank you received: 108
Reply to MARCOTEN:
Hi, Marcoten.
I don't have any 'pitchyers' of the 'hard bar' setup on a sideboom but it's not much different from the front-engined Cat Track loaders which had a rigid beam in place of the equaliser spring/bar and the end of the beam were bolted solid to the track frames giving rigid platform on which to mount eh appropriate attachments. Many smaller PAT dozers have a similar arrangement due to the inside mounted dozer push frame.
Wed, Feb 26, 2014 4:51 PM
