hand cranking a d311
mcd9
Send a private message to mcd9
I have a d311 #7s7623 I am playing with, and hope to get running. Did cat make a adapter for a hand crank on the d311, if so any numbers would help. Thanks Steve S
Fri, Dec 27, 2019 11:20 PM
STEPHEN
There may have been a provision for a service crank, but I have never seen one. Look to that fitting as used on a D4400
Sat, Dec 28, 2019 12:38 AM
Thank you received: 77
Reply to STEPHEN:
I don't have my parts catalog to hand but I'm not recalling a hand crank for the D311 - its predecessor the D3400 had one
Sat, Dec 28, 2019 1:06 AM
Steve A
I dont believe the front crank on a 311 was meant for starting, only service work. I would fear the man that could hand crank start a 311
Sat, Dec 28, 2019 5:28 AM
Jeff M.
Reply to Steve A:
We have used the service crank to start the pony it works very good and turns easy
Sat, Dec 28, 2019 6:14 AM
STEPHEN
If there are any around, I guess it would be more likely to exist on a power unit because they would be less likely to have a 44 pump mounted on the radiator. On the earlier D4 & D4 tractors most of them have been removed to fit a hyd pump to the front.
Sat, Dec 28, 2019 6:16 AM
Reply to STEPHEN:
Good luck finding one.....
Sat, Dec 28, 2019 7:06 AM
GrantJ
Thank you received: 10
On small (sometimes on older medium size) marine diesels there is often a hand crank setup but the ones I have seen crank on the cam shaft so the engine is turning twice the speed of the crank. Using a compression relief and cranking as hard as possible and turning the compression relief handle, and everything else is perfect, they will start. A Cat engine with a hand crank turning at the same speed as the engine (not double the speed) and a compression relief that is unreachable from the front, I doubt that it would ever work. I say this, but have never tried it with a Cat diesel so I am open to being proven wrong and learning something. Grant.
Sat, Dec 28, 2019 10:42 PM
cojhl2
Reply to GrantJ:
In general these engines must be turning about 200 RPM to even attempt to start. If slower the compression lost is too great to have the firing heat.
Sun, Dec 29, 2019 2:01 AM
