Hello folks,
My buddy just bought some land that came with a few pieces of equipment including a 1953 D6 PU that we'll be attempting to rehabilitate as time permits. I've just come across the operators manual and in the next coming weeks will be changing all of the fluids/filters prior to attempting to start her up.
Any tips or things to watch out for would be greatly appreciated!
Welcome to the Forum, you will find lots of help and information here, membership includes access to the library too. There are many things to consider, personally, for an initial startup, #1 priority - Oil in the Main and Starting Engines, as long as you have oil in the other compartments, I would delay changing them until I knew the Engine was good as well as the "running gear" (tracks, rollers, idlers, sprockets as example). No need in spending money on fluids until the conditions are known. Check the oil in the injector pump galley too. #2 - Air induction System, no intrusion from the "critters" and also have something at hand (immediate) to shut of the air supply in case of a run-away situation. That is important, there is no time to be looking for something if that were to occur. #3 Fire Extinguisher at hand - never know, cheap insurance. #4 -- ensure that nothing is interfering with any of the moving parts, fan, clutch compartment, etc. You do not want to start turning the engine to find something is bound up or lose and causes damages. I would suggest checking for water intrusion in the fuel system. Please, remember to always ensure the machine is in neutral, I prefer to have the clutch released too, less drag with the transmission that way. ( be conscientious of the starting engine and limited cooling capacity - some forget and run those engines for long period of time. I am not opposed to a light quick whiff of starting fluid if the main is hesitant to start, especially in cold weather. Don't overdue starting fluid - it will pre-detonate and can cause other issues.) PICTURES and Progress reports are always welcome and appreciated. - cts
Welcome! If you do not mind, please share photos. Plenty of shy folks here that like to "look". What part of the "Bay area"? There are several members in the Northbay or even Vacaville/Fairfield areas that are pretty savvy and occasionally take time from their busy lives to help fellow enthusiasts/newbies. It might be beneficial to share your approximate location.
If you ever purchase a J series machine, Mr. CTSnowfighter could share a lot about those critters. He is quite fond of them. Just ask him!
