Greasy problem
Greasy problem
Showing 1 to 10 of 13 results
blackdog006
Send a private message to blackdog006
Besides the fact it's Saturday I can't find any prices on 00 grease how ever I did find the local Deere dealer has cornhead tubes for 2.88. The Deere parts department guy said he didn't know if they even made 00 grease anymore or if they could get it. So now I'm sitting here trying to figure out how I am supposed to get enough grease to properly grease up this old 1940's D4 that I am trying to obtain. I would like to see what you guys have or recommend for roller grease for this old girl so I can get her nice and slick again. I am also trying to figure out if the standard giant button head grease fitting is the same as the old Cat fittings if it is I will get a pistol grip grease gun with a whip hose and a button head coupler. Also while I am at it what types of oil are recommended for the main engine and pony motor?
Sat, Mar 20, 2010 11:29 PM
TooManyIrons
Send a private message to TooManyIrons
You may want to contact Texas Refinery Corp, I bought a pail of 00 grease from them a few years back.
http://www.texasrefinery.com/
Sat, Mar 20, 2010 11:43 PM
Sasquatch
Thank you received: 5
Reply to TooManyIrons:
I called a local oil distributor close to me, they got me Shell "00" grease in five gallon pails, around $65 each. If you can find a business that specializes in oils close to you they may be able to help you out.
Sun, Mar 21, 2010 12:34 AM
Kelly
Reply to Sasquatch:
Try is. DA Lub Co. :RedPlex comes in grades of double 00., 1, 2. about $65.00 5gal. pal.
http://www.dalube.com/datasheets/redplex.PDF
Kelly
Sun, Mar 21, 2010 2:34 AM
Reply to Sasquatch:
The usual button head fitting is a little larger than 3/4" across the flat top and is the "giant button head" size. The" standard button head" fittings are about 5/8 in diameter.
Without the relief valve in the line to prevent over pressurizing the seals in the rollers, you will be better off with a pistol grip gun, so you can feel when it gets tight before it blows the seals. You'll soon look like PopEye the sailor man though. If you are going to do this very often, you will want a high volume/low pressure bucket pump with a pressure relief on it. Be prepared for sticker shock though. An old CAT pump begins to look pretty attractive sometimes when you compare to a new industrial model from Alemite etc.
Most any petroleum jobber (Chevron, Texaco, etc. should be able to fix you up with grease. JD or other machinery dealer is convenient for some folks because they usually keep the 00 corn head grease in tubes for their agricultural customers. They probably can also order it in 5 gallon size buckets or might even stock it in an area with lots of corn. I have only ever bought it in the tubes though. Tube grease is always more expensive than bucket grease, so you can factor some of the savings in grease to go into purchasing a pump and save your forearm muscles too.
Someone usually warns against using EP grease and gear lube in old CATs. I don't think this is a real issue any longer since the concern was that the EP additive package would attack the brass and bronze bushings in the component being lubricated. The manufacturers have found additive packages that do not degrade the brass. I know the JD corn head gear boxes that use the grease they sell have bronze bushings in them, so it's made to be used in contact with that kind of metal.
Sun, Mar 21, 2010 2:39 AM
B4D2
I have this in my file over on ACME. http://www.antiquecaterpillar.net/ACF_v2/attachment.php?attachmentid=6025 This is what I use.
Sun, Mar 21, 2010 2:57 AM
blackdog006
Reply to B4D2:
Thanks everyone, I was working with a fella up in Elk Creek Va. that taught me a bunch about older Cats and I am learning more every day. If you look at my new post you will see some pics of my prospect.
Sun, Mar 21, 2010 3:26 AM
PaulA
Send a private message to PaulA
Reply to blackdog006:
Make sure you need it before you go to all that trouble since you don't have the tractor yet. Later rollers have a plug instead of a button head fitting and do not need regular greasing. I have the sealed rollers on my D47U, a 6U parts tractor and a pallet of rollers I bought for spares.
Sun, Mar 21, 2010 4:39 AM
blackdog006
Reply to PaulA:
I will need it because I have a partner thats willing to kick in half of the cost then pay me for my half once I am done with the few jobs I have to do as well as pay me to operate it for him 😄
Sun, Mar 21, 2010 5:15 AM
chugwater crawlers
The Deere cornhead grease was recommended by someone on the board previously. I use it with a button head adapter that I can stick on my grease gun.
I use it on several tractors and it works good. It's a lot cheaper that a five gallon pail unless you have lots of tractors.
Sun, Mar 21, 2010 5:23 AM
B4D2
Reply to chugwater crawlers:
A constant reminder every time this topic comes up for conversation is that a hand-held grease gun is considered a high pressure pump and you run the risk of damaging the seals in the rollers. A volume compressor will move a lot of grease at lower pressures, thus preventing damage.
Sun, Mar 21, 2010 5:53 AM
| Kingaroy, Queensland
