Grader Tires coming soon
chriscokid
Well I had an excellent conversation today with a great tire supplier that is in the process of making 10.00-24.00 grader tires!
They are expecting the first batch to arrive in November, i would encourage you to call and put your name on a list to reserve you a set if needed.
https://www.millertire.com/categories/road-grader/
They also have front tire options:
https://www.millertire.com/categories/antique-tractor-tires/front/7-50-20/
https://www.millertire.com/antique-trucks-cars/antique-truck-tires/7-50-20/
Just passing along what i discovered for your information.
Wed, Aug 26, 2020 12:42 AM
Well I'll be damned! thats in my backyard! well kinda, more near Kenny Walkers I believe. I knew of them but didnt know they the grader tires. Good deal.
Wed, Aug 26, 2020 3:08 AM
Thank you received: 78
I've done some business with Miller Tire and have been very satisfied with their service - they have an extensive catalog and it sounds like it's going to become even better. A lot of low-volume special tires and rims
Wed, Aug 26, 2020 5:06 AM
janmeermans
[quote="chriscokid"]Well I had an excellent conversation today with a great tire supplier that is in the process of making 10.00-24.00 grader tires!
Just passing along what i discovered for your information.[/quote]
What I have found impossible to find is the 9:00 x 24:00 6 ply ribbed front tires for the Cat 112 early '50s. I have looked for years including the Miller website and also had a local tire dealer checking and so far "nada" nothing! Another one is the 18:00 x 24:00 scraper tires used on the LeTourneau units. I am told that 19.5 x 24:00 backhoe tires can be substituted but we have to get rid of the bee nests in the old tire first!
JanM
Wed, Aug 26, 2020 11:53 PM
chriscokid
Reply to janmeermans:
JanM
[quote="janmeermans"]What I have found impossible to find is the 9:00 x 24:00 6 ply ribbed front tires for the Cat 112 early '50s. I have looked for years including the Miller website and also had a local tire dealer checking and so far "nada" nothing! Another one is the 18:00 x 24:00 scraper tires used on the LeTourneau units. I am told that 19.5 x 24:00 backhoe tires can be substituted but we have to get rid of the bee nests in the old tire first!
JanM[/quote]
could you not use a 9.5x24 tire https://www.millertire.com/antique-tractor-tires/rear-tires/9-5-24_-9-24/
and heres you 18x24 tires https://www.stausaonline.com/tires/r4-industrial-tractor/
Thu, Aug 27, 2020 3:37 AM
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
Reply to chriscokid:
JanM[/quote]
that's awesome news - my 212 has 12.00-24's do you know if they make that size?
could put 10.00-24's back on i suppose too.
Nathan
Sat, Aug 29, 2020 12:55 AM
chriscokid
Reply to ironman3406:
Nathan
12.4-24 https://www.millertire.com/antique-tractor-tires/rear-tires/12-4-24_-11-24/
or
https://otrtires.com/yokohama-12-00x24-l5-y525-52503
or
https://www.ebay.com/itm/4-tires-12-00-24-tires-Hi-way-Express-A-P-truck-tire-12-00-24-20PR-120024-/192483419421
Sat, Aug 29, 2020 1:01 AM
oldbeek
JanM
JanM[/quote]tried to send a pm,,, ??? Get a hot shot no pest strip at hd or Lowes. $8.00,,, Hang it near the tire and cover the whole tire wit poly. Also if you have bees going in and out of a hole, cut a strip of it that will fit into the hole with still room for them to walk in and out. No pest strip is deadly on bees. Works every time. bees going in and out of a large area? Cover it with black polly. Cut a small hole for bees to come and go. Put pest strip in hole after they start using the hole.
Sat, Aug 29, 2020 12:49 PM
Reply to oldbeek:
If they're honey bees, get the local beekeeper to come get them. We need more bees. If they're wasps, get out the flame thrower! : )
Sat, Aug 29, 2020 7:20 PM
