Grader, 112 or 12
Grader, 112 or 12
Showing 1 to 10 of 21 results
lil cat mec
Send a private message to lil cat mec
i am going to be looking at a grader, not shure which it is, its off in the distance and talked to the gentleman, he said he purchased it for $2000 running but they pull started it, that makes me think it has a pony which i believe would make it a 112 right? anyways he said it has a cracked block but still ran good, no internal fluids mixing just leaks coolant. it ran good until a guy that borrowed it serviced it and since then it has not ran, he did change fuel filters so my assumption is that there is air in the injection pump/lines/injectors. He said its not worth what he payed for it due to the motors condition, i am just wanting to know what you guys think about the price and anything else, its just a mile or so from my house so if he is home tonight i am going to stop by and get a serial and some pictures, if not i will this weekend.
He also has a JD510 that the same guy borrowed at the same time, also servising it and when he got it back it runs verry rough and white smokes... so there is air in the lines. i am going to work on it this weekend and hopefully make a deal with him
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Fri, Jul 18, 2014 12:04 AM
Thank you received: 140
Hi, Lil Cat Mec.
12 has six cylinders, 112 has only four. Can it get much simpler?
Fri, Jul 18, 2014 2:14 AM
lil cat mec
Hi, Lil Cat Mec.
haha how are you Deas, i was starting to miss your humor lol!
I havent seen it up close, ill get some pictures and post within the weekend!
1935 CAT 22 2F4455W
Fri, Jul 18, 2014 2:23 AM
old-iron-habit
Reply to lil cat mec:
12 has D6 engine, 112 has D4 engine, and the little 212 has the D2 engine. All can have ponies based on the year.
PS. If I was that guy I would not lend the other gentleman any more equipment.
Fri, Jul 18, 2014 9:02 AM
lil cat mec
Reply to old-iron-habit:
[attachment=24348]20140717_201120[1].jpg[/attachment][attachment=24349]20140717_201128[1].jpg[/attachment][attachment=24350]20140717_201136[1].jpg[/attachment]i went and looked at it today it is a model 12 grader, it has 21,xxx hours!!!
also where are the serial numbers located? motor and grader?
1935 CAT 22 2F4455W
Fri, Jul 18, 2014 12:56 PM
Hi, Lil Cat Mec.
Mostly on left side front of frame just ahead of the scarifier mount and on right side of engine block toward the rear - flywheel - end of the donk.
If you get it and decide to get all enthusiastic and want to 'tighten it up a bit', there is a list of adjustments and how to perform them in the tech. library on this site. DON'T laugh! They are adjustable and I have seen blokes who had operated the same Cat 12 for NINE years and still didn't know there was any adjustment, let alone how many adjustments or how to do them.
CAUTION!!!!!!!!! Operator ASLEEP!!!!!!!!!!!
Fri, Jul 18, 2014 1:52 PM
old-iron-habit
Hi, Lil Cat Mec.
Thinking that in Washington, it may or may not have had a snow plow side wing on it. I didn't see the lift attachment in the pictures so it may not have. In this country 95% of the older Cat 12s had plows and nearly all of them have a cracked or usually broken main frame on the left side while sitting in the seat. They broke about a foot in front of the cab from hitting hard objects with the wing while plowing snow in road gear. Some are found repaired correctly while many are twisted up. Always worth looking for on the old machines. The old girl looks like a saver in the pictures.
Fri, Jul 18, 2014 8:26 PM
lil cat mec
Deas, i will be tightning it up, ill get the serial number here shortly. I don't recall it having a wing on it, how hard would it be to fabricate? I can investigate more on the frame, it doesnt concern me, i can either fish plate it and or v it and weld it along with a plate on the inside.
what serial variation does this appear to be "if you can tell form the pictures" also approx year? im not too up on my graders
1935 CAT 22 2F4455W
Fri, Jul 18, 2014 10:12 PM
Most likely an 8Txxxx model
Fri, Jul 18, 2014 10:28 PM
lil cat mec
would anyone by chance have a picture of the snow wing? also were there rippers for an option? front or rear?
1935 CAT 22 2F4455W
Sat, Jul 19, 2014 12:08 AM
old-iron-habit
Our City of Moose Lake still uses a Cat 12 equipped with V plow and wing to clear the city streets. I went over to the city shop at noon for some pictures to post but the 12 is all tucked away in the back corner of the shop with the plow and wing removed for the summer. The V plow in front raises from redirecting the scarifier shaft to the front lift. I have seen some that use the tilt shaft for the front wheels. My 11 has no front wheel tilt at all being ordered as a snow patrol. Guess they figure you don't need tilt if pushing a V plow. The wing has brackets and a bar off the back of the machine holds the wing out. It has a control shaft operated winch in front of the cab and lifts via a arraignment of pulleys and cable. I believe the 12 parts manual will show all the pieces under the attachment section in the back of the book.
Sat, Jul 19, 2014 1:27 AM
