Got tired of beating on master link today d7e
Showing 1 to 10 of 18 results
Cdcompton
Send a private message to Cdcompton
Wanted to share for others to see. I used oil, i used very little heat being careful not to temper the master link, i used the biggest hammer i had until i couldnt swing no more lol. So just for a plan b or idea for others, figured i would share my success. And i know im not the first one to build a home made track press but here is mine with a 50 ton bottle jack that got a very stubborn pin out....
Mon, Dec 2, 2019 10:00 PM
d2gary
That looks good, I've often thought there should be a good garage type method for pushing out pins.
Did the 50 ton Jack struggle or push it right out? Seems like I've read the hydraulic pin presses are 100 tons. Either way you got it out . Might be one in my future, thanks
Mon, Dec 2, 2019 11:09 PM
Cdcompton
Reply to d2gary:
D2gary beating all day pin moved 1/16 usually once they move your home free not this one i put the jack on it and it pumped up and jumped 1 time a good 1/4 then stopped so i pumped it up again and smacked the bottom of the jig under bottle jack with a sledge and it shot out with 1 hit. The pin had also been welded on both sides and had to remove weld with a cone shaped carbide bur bit on the die grinder. But overall i think when i have another one to do the time spent making this was worth it. Not sure i would have gotten this one with just a sledge like normal
Tue, Dec 3, 2019 12:20 AM
Thank you received: 289
Reply to Cdcompton:
I’m lucky to have “Gator” master links on my D7s! Sledge-O-Matic isn’t much fun on any pin. JM
Tue, Dec 3, 2019 12:57 AM
Thank you received: 227
Reply to Cdcompton:
Very nice looking jig, only thing I could add to it would be a ring on the pushing pin to keep it centered on the jack ram. Do all you can to avoid exposure - hide yourself from possible failures.
I sympathize with those fighting master pins - remember a D7E and frozen pin - 16# double jack, and cutting torch, all day affair in 100 F weather, no shade! Two of us earned our pay that day!
I operated a fixed track press in a Cat shop - had a cylinder explode! 8" cylinder coming apart is not something you want to experience. (No, the packing did not fail - the cylinder walls came apart!) Same thing happened some time later on same side of press, both of us were extremely lucky we were not hurt!
Pushing pins, master or otherwise can be very dangerous, use all cautions possible!
CTS
Tue, Dec 3, 2019 12:58 AM
Thank you received: 78
Reply to ctsnowfighter:
CTS
That's why I like the split master pins on the D2 because once the plugs are out, they virtually push out by hand. I realize D2s are small potatoes but the current master pins are just those solid pins and they do not move easily like the split pins do
Tue, Dec 3, 2019 5:30 AM
KellyD717A
Send a private message to KellyD717A
Not having the proper tools, nor skill, nor torch, but access to electricity, I used a Sawzall to cut my master pin and split the track on my old 17A. I cut the first side with one blade and about 10 minutes of sawing, thought I was pretty clever. For some reason, second cut took about 8 blades and about 75 minutes, but got it cut. There are always several ways to skin a cat.
Kelly D717A
Tue, Dec 3, 2019 6:02 AM
Reply to KellyD717A:
Kelly D717A
I like the Press!
Resourcefulness usually does not fail in getting a seemingly impossible task done!
Now can you "press" it back in with the same rig?
Tue, Dec 3, 2019 7:38 PM
doylex
Send a private message to doylex
Reply to drujinin:
I like the Press!
Exothermic torch = done
New pin and dry ice $30
Wed, Dec 4, 2019 7:31 AM
Reply to doylex:
"One stick of dynamite....free"
Wed, Dec 4, 2019 7:36 AM
Wombat
Donor
I'm with Doylex, it always astounds me the amount of money and labour people use to save a master pin that is only worth a few dollars. The master bush is not counter bored, as a result the master bush and pin wear faster, so best to fit a new pin and take up some of the extra wear. I always used a little colt oxy set, just gouged out each end and tapped out with a small 2lb hammer, a 15 minute max job for a D8H track.
Wombat
Wed, Dec 4, 2019 8:54 AM
