Got a tractor while the Cat HT4 is still "out of service"
Showing 1 to 10 of 12 results
JAKEcatHT4
Send a private message to JAKEcatHT4
Hey guys..how are you doing? I picked up an 08 branson 2910i. It came with a boxblade, bushhog and tiller. Had a few hundred hours. All for about $12,000..So far been pleased until I decided to get a speeco post hole digger. After some assembly and oil fill I decided to mount the phd and ran into a defect I guess. The boom mount wont slide into the gusset to get pinned. Has anyone ever encountered this?..I removed the top center link which the other attachments require. Went to stick the boom end in there and it was too wide.
Sorry this isnt a cat ? and will understand if deleted. Is there a chance that the phd has a bad U bracket welded on there?
Thu, Nov 17, 2016 10:53 AM
JAKEcatHT4
Here is a pic of her!
Thu, Nov 17, 2016 11:03 AM
mrsmackpaul
Reply to JAKEcatHT4:
yeah thats pretty common on a lot of smaller tractors most times you can just trim the sides off the implement to suit
Paul
Thu, Nov 17, 2016 3:53 PM
JAKEcatHT4
Reply to mrsmackpaul:
Paul
Thanks Paul. I probably will return this phd because of this and the fact that the U bracket was welded crooked and off center ..I just thought there would be a manufacturing standard when it came to implement hook ups. A standard dimension..The U bracket is flared pretty good on the leading edge. I thought if I could get some heat on it maybe I could bend it down to square. I dont know. Thats what I get for buying Chinese I guess.
Thu, Nov 17, 2016 11:47 PM
Common stuff from the land of "almost right".
Thu, Nov 17, 2016 11:54 PM
mrsmackpaul
very well put OM LOL
Fri, Nov 18, 2016 2:32 AM
hiwide 15
Send a private message to hiwide 15
In a couple years use this will fit right up as the almost right part will fit the made in USA made right implement. I like to buy older made in USA implement s if I can just because of this stuff.
Fri, Nov 18, 2016 5:33 AM
JAKEcatHT4
Reply to hiwide 15:
I hear ya. Well said!.
..messed with it a bit today. Did some heat and straightening. The whole damn thing looks pretty decent except where she mounts. The pics show the poor welds and off centering..
Fri, Nov 18, 2016 7:21 AM
Chuck C
Maybe its supposed to be off center. Try putting one leg in the middle of the tractor bracket and one on the outside. That might where the offset comes in. Just my opinion.
Chuck C
Fri, Nov 18, 2016 8:31 AM
JAKEcatHT4
Reply to Chuck C:
Chuck C
[quote="Chuck C"]Maybe its supposed to be off center. Try putting one leg in the middle of the tractor bracket and one on the outside. That might where the offset comes in. Just my opinion.
Chuck C[/quote]
Chuck, at first I did consider doing just that..well after scratching head and a few cursewords. The result of trying to mount on part of tractor bracket was that the pin wasnt long enough to pass thru completely. Also there was alot of play and sloppiness. .
Fri, Nov 18, 2016 10:56 AM
JAKEcatHT4
Chuck C[/quote]
So after alot of thinking I'm gonna take Paul's advice and grind down the sides. Did some measuring after I did the straightening with heat and it will still be about 1/8" too thick. Therefore I'm gonna remove about 1/16" from both outer sides. The boom is too cumbersome to hold up to my benchgrinder. So any ideas to do this?..handtool? right angle grinder?
Fri, Nov 18, 2016 11:04 AM
