Good parts sources
Good parts sources
Showing 1 to 10 of 13 results
WTE57
Send a private message to WTE57
Hi All-
I'm a new member at ACMOC and posted a list of parts I'm trying to locate for my 1959 D6 9U (s/n 2901😎 with factory hydraulics and blade. There have been a lot of views but no responses. I'm looking for the starter pinion sleeve and latch assembly (p/n 1F909/3B5440/3B5441/2A2350/2B1864/2B5122) and a replacement 4F7038 exhaust manifold. The old one is rusted beyond repair. I'm assuming that gaskets are available as aftermarket parts. Is that correct? If so, who do you recommend?
Also, has anyone ever fabricated the pony exhaust manifold (p/n 5H4035)? Mine is rusted out and I can't find a replacement anywhere. It doesn't look like a casting...
I'm not trying to poach folks' parts sources. Just need a little help to get started. The dozer ran 3 years ago and has been covered since. Looking to get started on restoration in the spring.
Thanks in advance-
Bill
Sun, Jan 9, 2022 1:36 AM
Thank you received: 77
Hi Bill, have you tried your nearest Cat dealer yet? They do still have some parts for older machines. Outside of that, searching for parts on machinerytrader.com will provide a list of vendors. One vendor that is commonly a great source is Florin in CA. For exhausts that are "just" tube, they're easy to make in an exhaust shop. Depending on the tube size, there may also be options to buy generic tube and cut and join to fit
Sun, Jan 9, 2022 1:40 AM
Florin Tractor 916-383-0317
FP Smith 70-312-7014
Chad Enyeart 307-760-8483
American Carne and Tractor 800-999-8538
Granger Tractor 330-239-1077
Zimmerman Tractor 573-378-7210
Sun, Jan 9, 2022 1:53 AM
WTE57
Thanks for the sources. This will help a lot. I'm in northwestern Mass and this is Deere country.
Sun, Jan 9, 2022 1:56 AM
Reply to WTE57:
Another good source for locating is Machinery Trader .com, search parts, just type in part #, for example, 2B2934 or if 2T55 type in 2T0055
Sun, Jan 9, 2022 3:59 AM
d2gary
General Gear in Boise, Idaho
Olson's Gaskets
Sun, Jan 9, 2022 4:17 AM
Reply to d2gary:
Olson's Gaskets
There's a member or two in your area that can help if you would like (No. Adams or thereabout)
Sun, Jan 9, 2022 4:23 AM
Hi Bill---where in NW Ma are you? I have my machines up there in Hancock---one being a 9u parts machine
Dan
Sun, Jan 9, 2022 9:02 AM
Cat112ftx
Send a private message to Cat112ftx
 [attachment=66247]C115166D-F82D-454B-BF7B-DE3011C3740A.png[/attachment]
[attachment=66246]BCEC97EF-1BE3-4F32-A8B8-28112B33CF49.png[/attachment]
 [attachment=66245]1FBA2D4E-35B2-40F5-9FBB-3CEF909691C3.png[/attachment]
[attachment=66248]BCC17DF4-E53A-4AC9-BAB8-95506E41EA26.png[/attachment]
I will include pics and prices from the cat website from what I could find. The 2 exhaust manifold numbers say they have been indirectly replaced, so they might or might not could help you with those with an updated number
Sun, Jan 9, 2022 9:45 AM
WTE57
Reply to dpendzic:
Dan
I'm in Rowe MA. My land borders VT.
Thu, Jan 13, 2022 3:29 AM
hfdzl
Reply to WTE57:
WTE57, I worked on the demolition and new bridge in Monroe, many years ago.1990
Thu, Jan 13, 2022 4:30 PM
