Good idea that went BAD!
Showing 1 to 9 of 9 results
Dunefanatic
Send a private message to Dunefanatic
I thought I would share some fun I had a month ago when the main California winter rains had stopped. I had purchased an Olive tree really cheap (kinda had it thrust upon me) which had a 36" x 36" base box. I got idea with some help of a friend to move the tree where I was going to plant it on the side of a hill near my newly landscaped front yard with my D2 Arch. Wife hates the looks of my logging arches but why not prove to the wife the arches value correct? 🙄
Well I learned the hard way that while the ground by my shop and on most of my property was firm and reasonably dry, that would not be the case where I wanted to plant this tree. I learned that when ground is wet as 2 minute oatmeal, you are bound to not get what you bargained for.
I posted a before picture when I was hauling the tree after just having picked it up by my shop and the after is fairly explanitory.
Three weeks after multiple instances of shoveling and letting the ground dry I was able to free the tractor and arch up and through my total stubborness and unwillingness to be beat I was eventually able to get the tree planted on the hillside.
Fri, Apr 16, 2010 5:10 AM
gwhdiesel75
Congratulations! Nice looking tractor, even if it was stuck! GWH
Fri, Apr 16, 2010 5:12 AM
Willie
Reply to gwhdiesel75:
Its goona look fun when te tractor you planted starts going . I guess you have to bring the tree to the tractor shoa and call it an Oliver they both are equil when working dirt LOL
Fri, Apr 16, 2010 6:45 AM
Dunefanatic
Reply to Willie:
You crack yourself up don't you Willie? 😄
See ya tomorrow.
Fri, Apr 16, 2010 6:53 AM
Frank Fox
Send a private message to Frank Fox
Reply to Dunefanatic:
See ya tomorrow.
😛 Thought he just lowered it.🙄
Frank
Fri, Apr 16, 2010 10:07 AM
7upuller
Reply to Frank Fox:
Frank
Willie,
I'm confused, did Dune sacrifice a D2 as fertilizer for the oliver tree?
Fri, Apr 16, 2010 10:16 AM
Willie
Reply to 7upuller:
Willie,
Yea its in the seat where he left it when it started going down faster then it was going foward.. Frank are you going to Tulare? should only be couple hours for you if you are Ill bring you a couple harvester books to use
Fri, Apr 16, 2010 11:02 AM
Orchard22
Send a private message to Orchard22
Reply to Willie:
it's cat-tacic!😮 , you're supposed to go muddin' with your 4x4 not the cat!!!😄 , it's a cat bush!!!😊 , quicksand!!😮, you know i thought about putting airbags on a cat but never seen it actually done before now you just need the flames&Mexican flag!!!😄 , i just couldn't resist!!!😄
1935 Caterpillar
Twenty-Two Citrus(or low top seat orchard)
serial number:2F2204
Fri, Apr 16, 2010 11:17 AM
Thank you received: 140
Reply to Orchard22:
Hi, Dunefanatic.
Ooooppss!!!!!!!!!!!!!!!! The best laid plans of mice, men and Dunefanatic.
So what does the cook think of the arch now?
I hope that when you had finished tearing up the landscape in such a disrespectful fashion, you restored it to its former glory.
Thanks for sharing.
Fri, Apr 16, 2010 1:34 PM
Thank you received: 62
Hi, Dunefanatic.
Thanks for sharing.
I would say that is a good reason to buy another Cat so you have one sitting high and dry and ready if the need for a tow should ever be needed again.
Ray
Fri, Apr 16, 2010 8:34 PM
