Glue brake linings?
Glue brake linings?
D6Rick
Send a private message to D6Rick
I'm putting new brake linings in my D7 7M. Is it a good idea to glue them to the bands in addition to riveting? If so what kind of glue or cement should I use. Thanks, Rick.
Tue, May 8, 2007 6:59 AM
SJ
Send a private message to SJ
I really don,t see where it,s necessary & Cat never did it on the machines like that & the bands flex some I,m sure when you apply the brake so if they are riveted on correctly I don,t see a problem with them.
Tue, May 8, 2007 7:09 AM
bob
Send a private message to bob
Reply to SJ:
I'm with SJ on this one. Any glued/ bonded linings are usually done by some factory process, not just something we could do at home. It would be a good plan to start your rivets and peen over a bit but not tight, so lining can move untill you get all of them in. Then start at the middle ones and work out to the ends of each piece.
Later Bob
Tue, May 8, 2007 7:13 PM
D6Rick
Reply to bob:
Later Bob
Thanks guys. We riveted the segments this morning and put it back together and she's working great Thanks again!
Wed, May 9, 2007 9:06 AM
