Glow plug voltage ?
Glow plug voltage ?
Showing 1 to 10 of 12 results
yohan
Send a private message to yohan
On a mid 50's D4 with the 24 volt starting system. What is the voltage for the glow plugs ? 24 or 12 ?
The book calls for the amperage to be 7 per plug but I cannot find the voltage.
Thanks guys and gals
Mon, Jul 20, 2009 5:59 AM
SJ
Send a private message to SJ
As far as I ever saw them yours still should be 24V if that,s what your system is.
Mon, Jul 20, 2009 6:09 AM
yohan
Reply to SJ:
Thank you SJ.
They are not connected now and I didn't want to burn them up if they were 12 volt
Mon, Jul 20, 2009 6:18 AM
bobcatd311
Send a private message to bobcatd311
Reply to yohan:
Thank you SJ.
Use an ohmeter to measure the resistance form a glow plug terminal (just 1) to ground. You do not need to have the glow plug out of the precomp
24 volts across 3.4 ohms results in 7 amps
12 volts across 1.7 ohms results In 7 amps
Voltage = current x resistance
Mon, Jul 20, 2009 7:14 AM
yohan
Reply to bobcatd311:
Thank you bobcat311
If they are bad, are they available items ?
The book shows them as 3H2033
Mon, Jul 20, 2009 9:01 AM
n7gxz
Send a private message to n7gxz
Reply to yohan:
Thank you bobcat311
Yes they are, here is a link to them.
http://www.truckengineparts.com/caterpillar-glow-plug-3H2033.aspx
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Mon, Jul 20, 2009 9:30 AM
yohan
Reply to n7gxz:
Kevin
Thanks Kevin,
Here is a question, sort of on the subject. I have a VW Rabbit that will not start unless you use the glow plugs. Turn the key to first position, and when the glow plug light goes out, turn the key the rest of the way and it starts almost instantly. I also have an 806 Farmall that has no glow plugs at all and it will start with very few rotations of the motor. Strange how one is so dependant of them and one has no need at all. Anyone know why?
Mon, Jul 20, 2009 9:58 AM
OldNuc
Send a private message to OldNuc
Reply to yohan:
Thanks Kevin,
Compression ratio and final compression pressure.
Mon, Jul 20, 2009 10:06 AM
yohan
Reply to OldNuc:
Ahhh, I was thinking the Rabbit has like 22:1. Do not know about the 806.
What would be the minimum needed to ignite the fuel?
So which one would not need the glow plug ? high or low?
Mon, Jul 20, 2009 10:18 AM
tanker
Send a private message to tanker
Reply to yohan:
Thanks Kevin,
[quote="yohan"]Thanks Kevin,
Thanks[/quote]
Pre chamber eng vs direct inj
Mon, Jul 20, 2009 10:39 AM
yohan
Reply to tanker:
Thanks[/quote]
Thank you Tanker, and all.
Mon, Jul 20, 2009 6:29 PM
