glow plug removal tool
grapegrower
Send a private message to grapegrower
Where can I purchase a glow plug removal tool D4 7U
Mon, Mar 16, 2020 7:30 AM
A 1/4" drive deep socket may work also.
Mon, Mar 16, 2020 8:17 AM
Do you mean a precombustion chamber removal tool?
The 7U uses the splined type 5F8353 which is available online from several sources including eBay or from your CAT dealer. There are additional tools available as a kit to remove and install the “retainer” around the top of the OEM style 2 piece chambers. Sorry but I don’t have a part number for that kit.
All replacement precombustion chambers available today are a single piece design and you need only the 5F8353 splined tool to remove and install them.
Mon, Mar 16, 2020 11:59 PM
grapegrower
[quote="ccjersey"]Do you mean a precombustion chamber removal tool?
All replacement precombustion chambers available today are a single piece design and you need only the 5F8353 splined tool to remove and install them.[/quote]
Thank you for the responces
I should have typed in D4 6U not 7U
Tue, Mar 17, 2020 1:26 AM
grapegrower
Reply to grapegrower:
[attachment=57772]IMG_0945.JPG[/attachment]
photo of D4 6U glow plug
Tue, Mar 17, 2020 2:15 AM
grapegrower
is there an existing thread with images on how to remove injectors and glow plug on ACMOC
thank you
Tue, Mar 17, 2020 2:26 AM
Thank you received: 31
thank you
Hi,
Scan below is for the tools in said kit. Not sure about the guides mentioned but are most likely to stop canting the wrenches and snapping off the glow plug body above the chamber as I think the early ones were less robust than todays designs.
The subject has been covered many times in the past and recently, albeit on a later series engine in boat I think, about how to align the pre-chambers to prevent glow plug interference with the valve cover etc. by using various thickness washers/gaskets to get into the go, no go range.
Tue, Mar 17, 2020 6:54 AM
grapegrower
Reply to edb:
Hi,
thank you for the reply and documents
Removed the inspection cover on the pump housing today. Had a friend turn over (electric start compression lever set to no compression)
I can only see one plunger barely move. That is my focus now. I have read the caution that must be taken taken fooling around with the rack and the plungers.
soaked them 3 times today (P😎 will take another look tommorow and try to get some movement on those plungers. Tractor has sat at least 10 years.
from the fuel tank to the pistons one step at a time.
Tue, Mar 17, 2020 9:49 AM
Thank you received: 46
Takes a special internal splined socket to remove the injector retainer nut former 2H7479 now 8S2243 available on ebay. With the nut removed there's plenty of room to access the glow plug. A through bore 5/16 socket can then be used or if you can find one that 1H5656 wrench.
Tue, Mar 17, 2020 12:53 PM
