Give the picture posting a try
Showing 1 to 9 of 9 results
biggastractor
Thought I would give the picture posting a try. If it work it should be a gas 70.
Biggstractor
Wed, Jan 31, 2007 10:42 AM
biggastractor
I guess I have to figure out how to resize them. sorry
Wed, Jan 31, 2007 10:47 AM
Delta Dirt
Send a private message to Delta Dirt
Reply to biggastractor:
BigAssTractor---
(always read your handle wrong)😉
I move my original picture over to Paint. Then utilize Stretch and Skew under View or Edit (unsure---but one or other)-----check picture size under Properties or Attributes. Keep reducing---until I get down to acceptable size for the thumbnail posting. Then save back into my photo program which is HP Image Zone.
You may not have Paint----but I would feel sure you probably have a similar program. Somewhere on here, Swishy has some instructions. Maybe somebody else will offer some specific help.
I am on dial up----and its just too much hassle going with one of the host programs.
Always enjoy seeing that big old gas 70. When you get your picture posting figured out----give us some spec's on it. How much gas per hour can it dispose of???😮
Delta Dirt
Delta Dirt
Avon, Ms 38723
D2 5U and other scrap iron
Wed, Jan 31, 2007 11:14 AM
King of Obsolete
Reply to Delta Dirt:
BigAssTractor---
Delta Dirt
if you have outlook express, email them to yourself and they are the right size. plus you get an email and feel loved too LOL
thansk
Wed, Jan 31, 2007 11:44 AM
alan627b
Send a private message to alan627b
Reply to King of Obsolete:
thansk
Guys, you need this little gadget to resize your pics, it's free and does a great job. I have done an entire batch of pics at once, it's very handy.
Waaay better than Paint, King! Faster too.
Powertools page
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
What you want is the Image Resizer, scroll down and you'll see it.
alan 627b
Wed, Jan 31, 2007 12:01 PM
D4Jim
Thank you received: 16
Reply to alan627b:
Powertools page
alan 627b
Another easy way to post pictures is to use a free hosting service like Image Shack and post the photo on the free site and then link it to the posting. The Image shack page gives you the "code" to paste in the message and then a thumbnail appears. It gives one the ability to post large pictures.
The picture below was taken today of a hay grinding operation just north of me. The milo bales and alfalfa were being mixed one to one and the grinder would handle about 1 of the 1800 lb bales per minute. Sure made it moan and groan and took two tractors to keep up with it.
[img]http://img411.imageshack.us/img411/9930/grindinghaymi4.th.jpg[/img]
Cats Forever
Wed, Jan 31, 2007 12:45 PM
Delta Dirt
Reply to D4Jim:
Alan---
Have downloaded----now will have to teach old dog to do new tricks.
1st trick is to find the program on computer.🙄
Delta Dirt
Delta Dirt
Avon, Ms 38723
Wed, Jan 31, 2007 1:19 PM
alan627b
Alan---
Delta Dirt
Delta Dirt, whenever you save a picture, whether it be to My Pictures or whatever folder you have created, all you have to do is go to where the image is, right click on the thumbnail, and a whole list of options will appear describing what you can do with the picture. Resize Image should be right there.
If you go to your MY Documents folder (It helps to make a shortcut to your desktop) and you find your pictures, you can resixe the whole batch at the same time using this tool!
If you wanted to resize all the pics in the folder, for example, you click EDIT+Select all+resize images. Or do one at a time. It works great! The time required depends on how fast your computer is, of course.
The resized pictures will be added to the folder, next to the parent image,
and labeled (for example) Cat D4 (small, medium, large) or DSC12000 (small, medium,large) depending on what size you select.
I know if I'm robbing pictures off a website, I like to label them with the serial number. Otherwise you wind up with stuff like D4-1, 2 or 1a, 2a...and then when you go looking for a certain pic, it gets confusing. Plus you gotta remember your labeling system....but, whatever works for you!
It all sounds harder than it is! I'm pretty much computer illiterate, and I figured it out!
Happy puting!
alan627b
Thu, Feb 1, 2007 5:51 AM
Delta Dirt
Reply to alan627b:
Happy puting!
alan627b
Alan---
Will get it sorted out when wife has time to follow through it with me.
Program looked good in what I saw last night----thanks for the additional instructions.
Delta Dirt
Delta Dirt
Avon, Ms 38723
Thu, Feb 1, 2007 9:17 AM
biggastractor
Alan---
Delta Dirt
Delta Dirt,
That 70 loves fuel. I bet it goes through 7-9 gallons an hour just monkeying around showgrounds. Fuel tank capacity is listed as 90. It's got someting like 2600 cubic inches. I don't know if I can flood it when cold. Floods easily when trying to start it warm. I can dump a lot of gas down the intake. My old heavyweight Rumley doesn't use any fuel in comparison. It's rated at 15-30 and will only pull a 5 bottom plow. The 70 is rated at 77-89. I pulled 6 bottoms one day in 5th gear at half throttle and the ground was rock hard. I wonder what it would do? Biggest gang plow available to me is 10 bottoms. Should try that this year. Would love to find a belt pulley for it!
Biggastractor
Thu, Feb 1, 2007 9:57 AM
