generator question
generator question
Chad Poe
Send a private message to Chad Poe
I have generator that is for use with battery. I want to run lights only with out battery. What is the difference in the generators and can I do this?
Wed, Apr 19, 2017 10:45 PM
What make generator is it? May be as easy as using a regulator with a "no bat" optional terminal instead of "bat" terminal.
Thu, Apr 20, 2017 12:03 AM
Chad Poe
Old Magnet, the generator is an american bosch and is stamped type 21.
Fri, Apr 21, 2017 3:14 AM
Reply to Chad Poe:
You apparently have a model ARKF 130/6-900 A 21 generator with a RGC6AS regulator for service with battery.
To run without battery you need a model ARKF 130/6-900 (6-volt - 900 rpm) B 21 generator with a RGC6C3 regulator.
The generators themselves are the same just the regulator changes the designation.
Without battery you would need to limit the generator output to no more than the 130 watts (1 watt is approximately 1 candle power)
Fri, Apr 21, 2017 5:49 AM
Chad Poe
Thanks for the info. Do you know where I could find the regulator ? Also , would that generator have been on cat gas forty? Thanks again for your time!
Fri, Apr 21, 2017 7:33 AM
Reply to Chad Poe:
Sorry I can't answer either one of those questions.
Fri, Apr 21, 2017 11:28 AM
