Generator gear
Generator gear
Showing 1 to 10 of 10 results
John-2210
Send a private message to John-2210
I’m looking for any information that might help identify the generator I’m installing on my ‘36 No. 10 auto patrol. It’s a Delco 953R and it came with a 26tooth unidentifiable gear. The engine I believe is the same as a Twenty Eight tractor. I’d like to add the generator and lights as I believe it would have had when Denver was plowing snow with it.
John
Sun, Apr 26, 2026 3:21 PM
naylorbros
Thank you received: 34
Here is a picture of a 26 tooth with part number.
Sun, Apr 26, 2026 3:43 PM
naylorbros
And a picture from the 4G series D4 parts book showing the gear
Sun, Apr 26, 2026 3:48 PM
John-2210
Thank you! I’m trying to add photos but no luck
John
Sun, Apr 26, 2026 4:40 PM
John-2210
John
Sun, Apr 26, 2026 4:41 PM
John-2210
John
Sun, Apr 26, 2026 4:42 PM
John-2210
John
John-2210
John
Sun, Apr 26, 2026 4:43 PM
John-2210
Ok so I had to post pictures one at a time but it looks like a match… 3b2770 gear. Does anyone know want the L-636 gear looks like or what a Delco 953R crosses to?
Thanks again for the help!
John
Sun, Apr 26, 2026 4:50 PM
Thank you received: 95
your Delco 953R crosses to a Caterpillar 1B5785.
In my No11 Auto Patrol Power Unit Parts Book the L-636 gear (21 Teeth) looks to be flat like what you have but as the illustration is front on it could be cupped--extended cone, you will have to do some measuring to see if a flat 21 tooth flat gear will align with your gear train at the mounting location with the gaskets and the spacer/adaptor in place.
Mon, Apr 27, 2026 1:04 AM
John-2210
Thank you Eddie I appreciate the help!
John
Mon, Apr 27, 2026 1:45 AM
