Generator For Cat 22
morgan1
Send a private message to morgan1
Does any one have any idea what I might beable to use for a Generator on my Cat 22.
Mon, Mar 28, 2011 9:24 PM
Dozerman51
I am not a gas Cat Guy, but I believe your machine calls for a Gen. with a pulley not a gear right? If so, you might be able to use a Delco-Remy 1102710 35Amp Gen. These and similar ones were found on 1940's GM product cars and trucks. You will need to have a Gen. bracket and strap etc. I put one on my D2/3J although I had the Cat Bracket and Strap already. Just had to make a new strap to fit the slightly larger Delco Gen. It fit real nice in the Bracket. The original Gen. was an American Bosch lights only unit which I still have. Needed to convert Because I added a Cat Electric start pony system to my D2. The voltage regulator to use with the Gen. is a Delco 1118301. Hope this helps you out.
Tue, Mar 29, 2011 11:12 AM
Catmatt
Send a private message to Catmatt
Reply to Dozerman51:
My cat twenty two that had a gen uses a gear not a pulley.
Tue, Mar 29, 2011 6:36 PM
morgan1
Reply to Catmatt:
Yes you are right I need a gear driven. Any Idea where I can find one
Tue, Mar 29, 2011 8:09 PM
dick
Send a private message to dick
Reply to morgan1:
I have several gear drive direct lighting generators, but you probably want the battery type. It seems I might have one with a regulator, will have to check. The correct gear will be the problem. Most of mine are for the three lungers or D50,D75,RD7,RD8. These all use an add on geared adapter on top of the timing gear train.
Tue, Mar 29, 2011 8:44 PM
