Gear oiling problem
Gear oiling problem
Showing 1 to 6 of 6 results
Don
Send a private message to Don
Just pulled the pony out of my D47U19643 and it looks like no oil is getting to the cam,crank or engagement gears at the rear of the engine.How do these gears normally get oiling? There is a plug at the top of the mag gear housing at the rear of the intake,can I route an oil line to this location to supply oil to these gears from the big engine?
Also I am looking for a new or used mag and cam gear.Also need a new or used armature as when the gear came off the armature shaft it broke the shaft.Also need an intake gasket for same,Thanks for any help.
Don Alves
Cat mag gear # 2A4144
Cat rotor # 4F3684
Cat cam gear# 4B870
Mon, Jun 2, 2008 1:18 AM
gemdozer
Thank you received: 25
I HAVE A COMPLET MAGNETO AND A CAM GEAR .
Mon, Jun 2, 2008 2:06 AM
SJ
Send a private message to SJ
Reply to gemdozer:
The D2 & D4 oil system is a splash system and that,s the way oil gets to all the areas so it,s a mystery why they would be starving for oil unless it was run low on oil.
Mon, Jun 2, 2008 2:15 AM
gemdozer
Reply to gemdozer:
I forget about lubrification the camshaft gear,crankshaft gear and idler gear recieved their supply of lubricant from the starting engine cluch compatment.
Mon, Jun 2, 2008 2:51 AM
Don
Reply to gemdozer:
gemdozer,where does the pony clutch fill at? I can not find any thing about it in my book.Do you know what kind of oil to put in it? Thanks again for any help.
Don Alves
Wed, Jun 4, 2008 5:50 AM
gemdozer
Reply to Don:
Don Alves
I found this in my servicemens reference book form 30522-1 page 246
and you can use 30 oil in .
Wed, Jun 4, 2008 7:41 AM
Reply to Don:
Don Alves
fill plug on top (or small plate with 2 bolts to remove on later models if you want to adjust the clutch) and check plug on front end of clutch housing. Also one on the bottom of housing to drain.
Wed, Jun 4, 2008 9:55 AM
