Reply to Mike Meyer:
For that serial number the parts book says
Oil Gauge 7F9064 sitting in a 7F9218 "Adapter" (From tractor D47U6676 Cat went to a smaller face gauge that sat in a special housing, the early larger face gauge is 8B2355)
Fuel Pressure Gauge 6B6158
Water Temp Gauge 4F8238
I think you will struggle to find the original style of gauge now but you should be able to find new gauges that will work, your local Cat Dealer should have the parts except possibly the water temp but I'm usually wrong! The ACMOC Club is in the process of making new old style gauges to suit our old girls and if you are not in a super hurry I'd suggest waiting till those are available this year hopefully, then your D4 will look "right", I believe the oil pressure gauge is first cab off the rank.
Mike
[quote="Mike Meyer"]For that serial number the parts book says
Mike[/quote]
Thanks for help Mike
