gaskets and gaskets ugh...
Showing 1 to 10 of 12 results
abram
Send a private message to abram
i need a TON of new gaskets for my 3J rebuild....are there any aftermarket makers? i know cat has alot but they are kinda a pain to deal with...i know you can make them but i'd prefer to take the lazy route ๐Ÿ˜„
3J5 D2
Wed, Nov 19, 2008 9:23 AM
bruce oz
Thank you received: 23
hello abram,olson's gaskets maybe your only help with gaskets ,bruce oz
http://www.olsonsgaskets.com/products.html
Wed, Nov 19, 2008 9:29 AM
Reply to bruce oz:
I have a CAT spare if you need. PM me. I made almost all the rest of the gaskets as I went along as it was a cheaper route.
Wed, Nov 19, 2008 11:10 PM
alan627b
Send a private message to alan627b
Reply to drujinin:
I got a catalog from these folks at Conexpo last spring.
http://www.bulldogkits.com/
Online catalog http://www.bulldogkits.com/catalogs/2006%20Bulldog%20Gasket%20Catalog%20Web.pdf
They list some gaskets for the J series and quite a few gasket sets for other Cat applications. Pre combustion chamber seals and other parts.
Hope this helps,
Alan627b
Thu, Nov 20, 2008 5:35 AM
abram
Reply to alan627b:
Hope this helps,
Alan627b
great, hey drujinin which gaskets do you have?
Alan - that was a huge help, i believe they have a basic and supplement kit for the d2...i believe it will supply all gaskets needed to rebuild the engine
3J5 D2
Thu, Nov 20, 2008 11:55 AM
alan627b
Reply to abram:
Glad to be of service!
Does anybody know of a source for obsolete trailer brake parts?
The brakes on my "new" 1949 LaCrosse trailer are Warner Electric's. I contacted the company but they don't support something this old..just wondered if anybody has a source? Don't know if it needs anything, but I like doing research in advance....at least the wheel bearings are Timkens!
Fri, Nov 21, 2008 3:54 AM
yancy44 mag
Send a private message to yancy44 mag
Reply to alan627b:
here are a few more http://www.gasketstogo.com/ http://www.enginads.com/bizcards.shtml
Fri, Nov 21, 2008 10:30 AM
Reply to yancy44 mag:
Hey alan,
I have been looking for the bulldog gaskets folks ever since I got some through Regal. I have catalogs for their hydraulic seals and cylinder components division, but couldn't find anything that related to gasket kits.
Thanks for the link.
Anyone know how to get this into the sticky parts source post?
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Fri, Nov 21, 2008 7:55 PM
Hey alan,
Alan,
I have an old trailer of unknown manufacture that needed brakes. I spoke to one of the local semi-trailer repair shops. They said that basically any electric brakes will fit based on the number of mounting holes on axle plus the distance between them and the diameter and width of the shoes. They said that you replace it as an assembly verses trying to put brake shoes on it because usually the electric armatures are worn out anyways.
Hope this helps!
Fri, Nov 21, 2008 9:08 PM
alan627b
Reply to drujinin:
Alan,
Hope this helps!
Drujinin, thanks for that information. It's something to think/worry about when I get around to tearing in to it!
Alan627b
Sat, Nov 22, 2008 1:59 AM
Soapy
Send a private message to Soapy
Reply to alan627b:
Alan627b
Redneck.com
Mon, Nov 24, 2008 9:24 AM
