gasket material for radiator
t20dozer
Send a private message to t20dozer
What is a good material to use to seal my 25 core to the tanks? i have a 1/8 x 1" cork is that good to use? thanks ian
Thu, Feb 7, 2013 10:30 AM
Mike Meyer
Thank you received: 6
I've used sheets of rubberized cork for that job available from any bearing or auto shop, it come's in different widths and thickness's and is not very expensive, and is usually sold here in Australia in 1 metre lengths, that's about 39", perfect for radiators.
regards
Mike
Thu, Feb 7, 2013 1:01 PM
Inter674
Reply to Mike Meyer:
regards
Mike
I used TEADIT 1.5mm rubberised non asbestos material,not cork, harder than that which reduced compression. It worked very well.
see http://www.teadit.com/
NA1122
Thu, Feb 7, 2013 5:02 PM
1/8" is a little thicker than would have been there originally. If you use it, be careful not to over tighten the bolts and dimple the top and bottom sheets around each hole.
Thu, Feb 7, 2013 9:40 PM
| Kingaroy, Queensland
