Gas motor in a 5M grader
Showing 1 to 10 of 10 results
LJMACKS
Send a private message to LJMACKS
Can someone help me identify which gas motor is in my 5M88 212 grader and what else would it have been used in ? Bill A
Fri, May 17, 2013 8:46 AM
Same motor as used in the 30(6G)/R4.
4-1/4" bore 5-1/2" stroke
4400G
Fri, May 17, 2013 9:20 AM
Hi JM, I believe the 28 crawler tractor used the same engine.
Fri, May 17, 2013 9:22 AM
Sorry was thinking of maybe the 112.
Fri, May 17, 2013 9:23 AM
Gosh my clutch must be slipping lol sorry Bill.
Fri, May 17, 2013 9:25 AM
Unless it's really 1M88, you have a 112 grader made in 1942 from the information I have. Old Magnet has the engine specs pegged.
Fri, May 17, 2013 9:41 AM
chriscokid
more grader info http://www.chriscomachinery.com/Graders.htm
Fri, May 17, 2013 10:00 AM
LJMACKS
Reply to chriscokid:
Sorry about the mistake! The grader in question is an 8M88. No 212 gas motor single wheel drive. Bill
Sun, May 19, 2013 1:46 AM
LJMACKS
Reply to LJMACKS:
After looking at Erik's Chapter 12 info, apparently the motor is a 3-1/4 X 5 same as an R 2. Was this used in anything else and does it have a specific model no. ( such as 3400 or 4400 for example ) ? Thanks all!
Sun, May 19, 2013 2:06 AM
Reply to LJMACKS:
That's 3-3/4" bore x 5" stroke 3400G engine.
R2 option is it.
Sun, May 19, 2013 2:46 AM
LJMACKS
R2 option is it.
Thanks OM and all others!
Sun, May 19, 2013 3:03 AM
