GAS CAT 30 RAD CAPS
GAS CAT 30 RAD CAPS
Showing 1 to 9 of 9 results
Catman
Send a private message to Catman
GAS CAT 30 RAD CAPS .
Cat-Cave CAT 30 RAD CAPS.
I myself Have GONE BACK TOO BLUE PRINTS, on the CAT GAS 30 RAD CAP. And Fitted a Bronze Bush on the Radiator HEATER to Get " BACK to SPEC" RAD CAP..
Fully Cored Out. Manufactured as Per CATERPILLAR Blue Print Data.
ON THE ACMOC FORUM PAST POSTS ASKING FOR CATMAN TOO RE-CAST MORE PARTS. TOO HELP NEW FELLOW ACMOC MEMBERS WITH MANIFOLDS , DECALS, ETC ETC ETC
SO QUESTION ?. WHAT DO YOU ACMOC MEMBERS WANT TO PAY FOR NEW CAT-CAVE RAD CAPS.
PHOTOs showing FULLY CORED PRE OVER SIZE Cross Drilled or Raw Casting.
So QUESTION. to ACMOC MEMBERS ?? WHATS THIS PART WORTH ???
www.cat-cave.com
Fri, Dec 5, 2025 11:45 PM
Catman
TRYING TOO ADD PHOTOS ,,,,,,
FACT. I POSTED UP ABOUT THESE CAT 30 RAD RAPS ON ACMOC FORUM A LITTLE WHILE AGO.. NOT TOO LONG AGO HEHE. CAT-CAVE WORKING ON REBUILDING 8 Cat 30's From Tailseals, Top Seats, Wide Gauge, Narrow Gauge, Split Heads in Wide Narrow, Canopies ETC ETC, CAT 30's From S and PS thou the Years. TOO Having the Last Build Split Head Wide Cat 30 PS. In the LINE UP from BEST 25 BEST 30 2 SPEED (EARLY WITH INTERNAL WATER GALLERY, 4 SPOKE IDLERS ETC. ( ONLY SIX OF THESE VERY EARLY BEST 30 KNOWN TO EXIST.
CAT-CAVE HAVE SPENT THE LAST 20 YEARS, REMANUFACTURING , FORGING FINAL DRIVES, GEAR CUTTING, HEAT-TREATMENT. PANTERN MAKING PATTERNS for CASTING IN BOTH MANY SPECS of CAST STEEL, and CAST IRON MIXES. To REBUILD THIS VERY RARE C.L.BEST EARLY 30 Machine. SPECIAL THANKS TO CAT INC. FOR MAJOR HELP IN FINDING THE C.L.BEST BLUE PRINT INFO. MANUFACTURING PROCESS DATA for C.L.BEST on the SIGNED BLUE PRINTS.
CAT-CAVE has CAST to BLUE PRINT SPEC the RAD CAP for Our Own Collection.
THE POST ON ACMOC TURNED INTO ACMOC MEMBERS WANTING OVERSIZE RAD CAP.. OK
FACT.. THE CAT-CAVE HAS ONLY EVER SOLD GENUINE CAT-CAVE PARTS (BACK TO BLUE PRINT DATA). Passing Engineering Inspection Process. Before Sold as a GENUINE CAT-CAVE PART TO CAT FATORY SPEC.
FACT CAT-CAVE MANIFOLD DEPT ,, IS FOR THE VERY 1st TIME. LOOKING AT.. CAT-CAVE CASTING MANIFOLD CASTINGS RAW CASTING'S. AND SHIPPING TOO OZZY. FOR OZZY BIG COLLECTOR
I Myself have seen at USA AUCTION. A GENUINE WORN OUT (RATTLED THREADS AWAY) GO UNDER THE HAMMER DROPPED AT $380.00 for USED GENUINE RAD CAP.
I WAS THINKING.. RAFFLE a COUPLE OFF,, HELP THE ACMOC CLUB WITH $$
www.cat-cave.com
CM
www.cat-cave.com
Mon, Dec 8, 2025 12:32 AM
catrjw
Send a private message to catrjw
I have been waiting to be approved to catcave to buy some decals for some time . Am I doing something wrong?
Mon, Dec 8, 2025 12:08 PM
8C 361
Thank you received: 12
Are they real decals or stickers?
Mon, Dec 8, 2025 1:59 PM
Catman
Reply to 8C 361:
QUOTE.
REPLY FROM CATMAN. 8C361. You Should know by now. Cat-Cave Only working to CAT HQ Genuine Factory DATA. Screen Printed GENUINE to CAT FACTORY DATA. Stick them as STICKERS on your Workshop Wall If you Want.
www.cat-cave.com
CM
www.cat-cave.com
Sun, Dec 14, 2025 12:01 AM
Catman
Reply to catrjw:
catrjw. Merry Christmas ,,, Back at You and Special Thanks for your Private Message.
TRUST CATMAN. WHEN CATMAN SAYS " GETING IT DUN ". DUN it Will Become.
CATMAN. HAS GOOD HISTORY FOR GETTING ANTIQUE CASTING ETC ETC DUN and DELIVERED .
I have just Finished Wrapped up "Boxed UP", Over 20 Boxes for USA XMAS ORDERS ""IN TIME FOR CHRTMAS DAY" CATMAN SANTA DELIVERY HEHE.
I need to APPOLISE to MATT VERCAMP. ( Good Old Buddy.) Your Order will Arrive 27th .
CM
www.cat-cave.com
Sun, Dec 14, 2025 12:26 AM
Deebo
Librarian
Thank you received: 107
CATMAN asked me to post photos of the rad caps as he was having issues putting up the photos. Great work!
Sun, Dec 14, 2025 8:36 AM
Thank you received: 222
Very Nice - Pineapples! -- cts
Sun, Dec 14, 2025 2:44 PM
Catman
Deebo Thank You for Posting up the Photos.
ctsnowfighter. Thank You Very Much for your comment. I am Sure Yourself Posed up Many Times on my ACMOC POSTING on the Previous Forum Platform a While ago. Our C.L.BEST 2 Speed Thirty. Had the Original Rad Cap Sitting on the Header Tank. Worn out No Threads on Header Tank or on The Rad Cap.
Cat-Cave Working back to Making PARTS BACK to FACTORY SPECS. We Manufactured New Cat 30 Rad Caps and Machined the Thread to Factory Spec. And Then Machined Bronzy Bushes Press Fit into the Headers on all 8 of Cat-Cave BEST // Cat 30 Collection Machines.
CTS. We Followed the Factory Production Method. Casting Split Line around the KNOBBLES AREA. With a Large Mushroom Shaped Core Inside "As PER FACTORY".
CTS. I have Seen at Auction in USA. A Cat 30 Rad Genuine Rad Cap.. Hammer Down at $380.00.. With Several Bidders Bidding UP.
CTS. I Have been Sending my Cat Cave Buddies A FREE OF CHARGE. Cat 30 Rad Cap with Many Cat-Cave Caterpillar 30 Manifold Orders. HENCE THIS POSTING ON ACMOC. ??? REALLY WHAT IS THIS RAW CASTING OVERSIZE PINEAPPLE WORTH in USD $.
CTS. Send myself Email with your Address to Ship Too. I will Send you a Pineapple over if you want one ? HOWS THE SNOW YOUR SIDE
CM
www.cat-cave.com
Tue, Dec 16, 2025 12:09 AM
Catman -- Thank You for your kindness and exemplary work. When I owned a Thirty, the cap was as you said, just rattling around in the hole of the top radiator tank. I do not think I ever saw one here that was not in that condition. I would have no purpose for the cap but would be most happy if you found someone that needed one and could put it to good use as they were intended. Value - what the buyer is willing to pay and the seller willing to accept. Snow -- I left the snow removal side about 30 years ago now. Most snow here was what we called "sierra cement", wet, heavy and compacted to sheet of solid ice when run on with traffic.
I am reasonable sure I have posted this photo previously - Donner Summit Rest Area (West Bound) 1982, Case W-18 loader with Snow Blast rotary - power for the rotary was 3208 Caterpillar. Elevation 7239'
Tue, Dec 16, 2025 2:44 AM
