Gas 65 Radiator
Gas 65 Radiator
Jbayer
Send a private message to Jbayer
Working on replacing a few tubes. Looks like 1/2 inch tubes but don't know what to do about fins. Anybody got a source. Some of them are soldered on. Also need a left side bracket. Any knowledge welcome,
Thanks,
John
Sat, Nov 21, 2009 10:12 AM
acat65
Send a private message to acat65
John, You will have to have it all apart;on ours we found enough fittings to complete ours,but we used fined tubes on outers and regular copper tubing inners.if you know wher to look you might see the plain tubes but I can't tell by looking. for the sides you will have to have recast from existing ones because there were only 500 plus made
Gene
Mon, Nov 23, 2009 2:19 AM
Bruce P
Thank you received: 38
Reply to acat65:
Gene
John, My shop air compressor has fins on the line running from the first stage to the second stage. They are soldered on. I would talk to someone that repairs heavy industrail compressors, surly there is a sorce.
Hope this helps and good luck!
Bruce
Mon, Nov 23, 2009 10:18 PM
