Gardner Denver Vertical Air Compressor ,, AND Caterpillar 318 Power Unit ..
Showing 1 to 9 of 9 results
D6 Pete
Hello ALL  ,, id like to find a manual for my Gardner Denver  Air Compressor ,, its a Model WHF 2003.  Ser # 202741. ..  Its driven by a Cat 318.    Same as the U series D6  etc ..   Power. /   Thanks for any help ..  ..  Regards to all  pete.    ps   THATS a manual for the  COMPRESSOR  ,,,    not the  318.. ALL good for the  Cat 318 ..
Fri, Sep 29, 2023 11:32 AM
D6 Pete
TRYING a PIC !!
Fri, Sep 29, 2023 12:20 PM
Thank you received: 55
Reply to D6 Pete:
TRYING a PIC !!
well the engine will be an industrial 318.there is a book specific to the engine. but a book for the grader or dozer with the 318 engine will work in a pinch.
Fri, Sep 29, 2023 4:29 PM
Thank you received: 140
Reply to trainzkid88:
Hi, D6 Pete.
I think the main differences between the grader or dozer variants and your engine would be in the oil pan and pickup and in the governor.
Fri, Sep 29, 2023 5:11 PM
That is a Beautiful unit!! Mine is a Joy
  [attachment=73858]Joy 10-11-20.JPG[/attachment]
Fri, Sep 29, 2023 7:51 PM
Thank you received: 62
The Cat service manual on the D318 has sections on the industrial and generator versions of the basic engine covering governor settings and such. But would guess you knew that and are looking more for the service manual Gardner-Denver most likely had.
Sat, Sep 30, 2023 2:59 AM
D6 Pete
Reply to Ray54:
NO  not for the 318   Im looking for a manual for the  COMPRESSOR  !!!.  Thanks for any help  ....pete
Sat, Sep 30, 2023 10:39 AM
Reply to D6 Pete:
see if you can find a group for them. we most likely wouldnt have it. try a google search of the model number for the compressor.
Sat, Sep 30, 2023 3:27 PM
Hi, D6 Pete.
Try this link, M8. I did a search for"Gardner Denver compressor group", and this is the result. There will be more below what is shown at first.
https://duckduckgo.com/?q=Gardner+denver+compressor+group&t=newext&atb=v331-1&ia=web
Sat, Sep 30, 2023 4:50 PM
D6 Pete
Hi, D6 Pete.
Cant find as yet .. Thanks all same ..
Tue, Oct 3, 2023 2:11 PM
