Fun caterpillar weekend. It runs.
white halftrack
Send a private message to white halftrack
Had a very eventful weekend with the d69u. We checked filled fluids and tried to drag it with my d2. No go. Ended up getting a farmer with a large tractor to pull it. After some smoke it started! The engine extremely well. Everything work except the left turn and three of the upper rollers are locked. So will be working on that and asking about removal. Does cat have those button grease zerks?
The next day we drove through Bartlett ne to pick up a Kaiser dragon for my brother. On the way we ran into this d7 serial 3t297sp. Tractor was rough but the blade was really really nice. It was a 7s. Wish it would work on my d6. It is available. The same older gentleman had the two scrapers in the trees. They are also available but beyond my capabilities. The d7 is a 1944 and I can see army green under the yellow. Was a very interesting day. I will be asking questions later on the steering clutch after I look through archives a bit.
Mon, Mar 7, 2016 8:26 AM
white halftrack
More pics. If anyone is after a d7 I would go in on it if I ended up with the blade. The pony turns nice.
Mon, Mar 7, 2016 8:32 AM
mog5858
Reply to white halftrack:
nice find there it's all way fun to keep a eye out and see what you find. you did very well this time. thanks for the pics
Mon, Mar 7, 2016 10:11 AM
cheshire cat
Send a private message to cheshire cat
Reply to mog5858:
Sounds like a result !! Nice work , Not sure if you can still get the button head zerks but if your rollers have a pipe plug they might be the semi sealed type and use oil rather than semi fluid grease ....
Mon, Mar 7, 2016 2:02 PM
Thank you received: 138
Reply to cheshire cat:
Hi, White Halftrack.
That first photo that you posted - is that the edge of the world that Columbus never found so that he could fall off of it??????????? I KNOW it ain't a DowNunder photo 'cos I nearly got a crick in my neck trying to look at it. Or have you bin takin' photo posting lessons from Oil Slick???????? LOL.
A kew-ree-yuss mind would like to know.
Mon, Mar 7, 2016 2:50 PM
Button Head Zerks can be procured through McMaster-Carr. They are also available on EBay, just be sure to check your size before ordering through either source.
Mon, Mar 7, 2016 7:24 PM
