Fuel pump issues D4 6U1141
Thank you received: 233
I had a hard time starting one of my D4s yesterday. I had a stuck plunger on #1 again; freed it up and gave it some liberal spray lube. I rarely start this machine to use, WHY is the plunger sticking? Bad fuel? I ask this, as I also had other machines which I use regularly that refused to start.
This particular unit also had fuel escape after I removed the access panel. I will inspect it and look for seepage.
I do not have anything going into the crankcase. Have I lost the 2 seals for the pump/governor or? It seems to be a never ending thing here. Too many machines, so little time.
Mon, Dec 22, 2025 3:47 PM
Thank you received: 19
Hi JM,
modern diesel fuel has less sulphur and less lubrication ability and is hard on plunger type injection pumps.
Some 4x4 forums recommend adding a dose of modern two stroke engine oil to the fuel to stop the sticking and wear.
Recommended Ratios & Amounts:
Your experience may vary.
Machines with worn plungers and barrel bores can by-pass fuel when static for a long time--check the drain tube that should drain the lifter and pump cavity of the fuel injection pump. On D2/4's there are 2 or 3 tubes down below the injection pump filter tower at about the same level as the sump/crankcase parting line that mud daubers love to clog up.
Tue, Dec 23, 2025 1:41 AM
Thank you Eddie B., I will take a look today while I am close by. What is your thought regarding the use of ATF, Marvel's Mystery Oil besides 2 stroke oil? This one for sure has not been started in over 6 months, and honestly never ever noticed anything come from the weep tubes, so there is a good chance they could be plugged up. I might have to swap the ditcher attachment for the toolbar blade, so I can spread some crushed rock here. Good excuse to stretch its legs.
I really appreciate your wisdom. Thank you again, JM.
Tue, Dec 23, 2025 2:44 PM
Hi JM,
ATF will both lubricate and eat rust, we do not get Marvel Mystery Oil down here so I have no experience of this product.
Wed, Dec 24, 2025 1:02 AM
Thank you received: 97
Hi, JM.
One 'trick' that I have used for a LONG time is to add the 2-stroke oil into the tank BEFORE filling the tank. If the tank hazza dipstick, 'kalkillate' the amount of 2-stroke oil that you need for the amount of fuel that you will be putting into it, add the 2-stroke oil and then let the incoming fuel do the mixing for you.
Many, MANY moons ago, back in 1971, I discovered that Australian BP pre-mixed 2-stroke fuel was the ONLY one on the market at that time in which the 2-stroke oil would not separate from the gasoline in the mix if left standing for a while - dunno if the same still applies.
Wed, Dec 24, 2025 3:39 AM
Thank you received: 47
they don't make zoom any more. that went out in the early 90s/late 80s. i can just remember servos having the bowsers for it. you can still get sthil motomix though pre mixed premium unleaded at 50 to 1 ratio.
what we use is flash-lube diesel conditioner 50ml to 50 litres. works well adds that lubricity back and has a slight cleaning effect too.
we also use flash-lube valve saver for our old petrol engines too since modern fuel is unleaded.
Thu, Dec 25, 2025 1:32 AM
