fuel pump
fuel pump
TracksNIowa
Send a private message to TracksNIowa
I know this is redundant, but i would like to find who is selling the fuel pump diaphrams for the cat gassers. I have seen it on the board before but couldn't come up with anything with the forum search. The pump in my forty is down and out and I would like to get it going bc spring is coming. Thanks in advance,
Beau Nelson
Thu, Mar 22, 2007 7:13 AM
SJ
Send a private message to SJ
It,s been awhile ago someone listed an automotive diaphragm as a direct replacement but don,t know if it was for a 40 or not so maybe they,ll come back to you on them.
Thu, Mar 22, 2007 7:19 AM
Reply to SJ:
Check Willies site http://www.westernfarmcollectables.com/
He has diaphragms for sale but I can't tell you if it's for the forty.
Thu, Mar 22, 2007 8:41 AM
Jon
Send a private message to Jon
I got mine from John Matta the one Willie has is for the potmetal fuel pump for a 22. Item 5
Thu, Mar 22, 2007 10:59 AM
Willie
Reply to Jon:
The dia. I have are for the pot metal AC pump and its a standard 50s-60s ford part with dia crimped to rod, if you have a brass pump then you just need materal, they have nut inside to hold together . All the fuel pumps on a gas Cats are interchangable they only have diff. arm length to ride on cam. 30-40-50-R4-R5-22 and they came in AC or Stewert-Warner
Thu, Mar 22, 2007 12:18 PM
