fuel in oil d6
fuel in oil d6
cl60
Send a private message to cl60
Hi need some help with a D6 #2h8309
oil pan has diesel fuel
full pump seal my be out
Sun, Jul 1, 2018 1:42 AM
More likely a shrunken fuel gallery O-ring 8B4967 between the injection pump and the filter tower. Common leak source on all the early Cats. If the transfer pump seals were leaking it would show up at the tell tale drain line that drains the seal cavity.
Sun, Jul 1, 2018 7:20 AM
