Fuel in oil
Fuel in oil
Showing 1 to 10 of 17 results
cab
Send a private message to cab
Have a major fuel leak into crankcase on the d8h. Is it going to be the oring on injector pump/governor housing or is there another way it could be getting in?
Have also noticed pressure in fuel tank which could be speeding up leak.
Took the lockable fuel cap to pieces to clean vent and it has a check valve that lets air in but not out??? Feel like the cap should vent both ways.
Sun, Feb 14, 2016 3:55 AM
Hello cab, ya it should vent. Sounds like it may be the transfer pump seals. Pretty easy to take apart and fix.
Gary
Sun, Feb 14, 2016 4:25 AM
Gary
Fuel leaking past the transfer pump seals would show up in the tell tale drain line. The most likely source of leakage is the o-ring seal between the governor housing and the injection pump housing. Same 8B4967 o-ring (-31😎 and ferrule that they all use.
Sun, Feb 14, 2016 5:08 AM
Your right mag, it does have a drain line. Thought that was making the pressure in the tank. Wouldnt have good fuel pressure on the gauge if the relief spring was bad or not seating.
Sun, Feb 14, 2016 5:15 AM
Thank you received: 95
Hi Cab,
we may need a Serial Number so as to know what injection pump is fitted--later units have a compact style pump and not the forged body type, so we can give a definitive answer. Scans below show a Forged Body Pump and a Compact Style pump--D8H is similar but is squarer where the fuel gallery is.
A tank that is pressurised puts undue pressure into the fuel gallery which keeps pressure on the injection pumps plunger and barrel clearances--although minute-- and leakage past these will show after time--especially on the compact pumps as there is no rack cavity drain as on the forged body pumps.
If the transfer pump drain line is blocked and the fuel seal is faulty, along with the pressurised tank you found, then the fuel can be forced across thru the transfer pump seals into the engine. Usual suspects for blocked drain line is mud buildup in the belly guards, or mud daubers.
Also check the drain line from the rack cavity--behind the side plate--to see if it is blocked also.
I have not encountered one way breathing fuel caps--always open to learning something new. Only alternate style attachment or cap is those for fast fill systems but I doubt they are one way either--maybe if one of these is fitted the drain/breather plastic hose is crimped over or sitting in crud under the fuel tank especially if the fast fill is not used.
Sun, Feb 14, 2016 6:16 AM
cab
Reply to edb:
Hi Cab,
It is definitely the earlier, larger forged body. I will check drains before going straight to o-ring.
Cap is the fiberglass/aluminum unit made to accept a padlock. It is a Cat product but may have been used in later machines that had an integral tank vent. Will be easy enough to gut the check valve and make it vent. Wondering if I should do that and see if it is still leaking before digging further.
Sun, Feb 14, 2016 7:55 AM
catsilver
Reply to cab:
As far as I know, all Cat fuel caps are vented with a metal filter inside them, if it is not venting both ways, it is clogged with dust.
Sun, Feb 14, 2016 5:12 PM
Reply to catsilver:
Couldn't hurt to vent the Cap, maybe cheaper than tearing into the tractor looking for a bad seal!
Sun, Feb 14, 2016 8:08 PM
Reply to drujinin:
Good logic would be to change a 25 cent o-ring seal along with some gaskets when this is a known failure item after 40-50 years rather than risk a main engine bearing failure.
Knowing cab, he's probably already got the work in progress.
Mon, Feb 15, 2016 12:05 AM
cab
Here are some pics of the mysterious 1 way cap that allows air into tank but keeps the tank from expelling any built up pressure. I gutted the check which is the yellow circular item in last pic and reassembled. After draining umpteen gallons of diesel/oil mixture out of crankcase until it stopped dripping out, I opened cutoff valve below fuel tank and sat and waited with drain plug out of oil pan. Sure enough, a faint stream of diesel started dripping out. OM, you are correct, I am already in progress on the teardown for o-ring replacement. Guess my fear of disappointing you outweighs my laziness! In all honesty, I like to logically work through things in my mind so that I understand where I am before I start turning nuts, but as usual you were right again.
Mon, Feb 15, 2016 10:26 AM
Reply to cab:
I see a part number 7X7700 on the cap which doesn't seem right for your unit. I'll look into it.
edit:
Original locking replacement for the standard 4B5441 cap is a 5S8033 which turns into a whole string of equivalent replacement numbers.
5S8033=1S6307=5G3612=1P8678=5A5031=5A7550
Mon, Feb 15, 2016 10:33 AM
