From The Model Show Thread
Art From De Leon
Send a private message to Art From De Leon
What is the purpose of this blade in the real world?
[attachment=34779]29758b3f31579db6a7ca75fe5cebee43-Modelshow Europe 2016 (465).jpg[/attachment]
Most Impressive! (I can't even follow a straight line, which leads to some creating decorating)
[attachment=34780]7f414b9d78b53c5a2fd7dbe6e48c37a3-Modelshow Europe 2016 (600).jpg[/attachment]
Fri, Apr 8, 2016 1:35 PM
mrsmackpaul
yep the wooden digger is impressive got no idea what the purpose of that blade would be for maybe if your working on a slope less material flows to one side but I really have no idea
Paul
Fri, Apr 8, 2016 2:02 PM
old-iron-habit
Reply to mrsmackpaul:
Paul
Might be for pushing on the huge coal, taconite, or ore piles. It has what I believe is the rescue pod and emergency locator beacon on it for if it falls into a void in the pile made from conveying out from the bottom.
Fri, Apr 8, 2016 7:05 PM
QuAD
Reply to old-iron-habit:
Its a CARON Double Semi-U Trashblade
Patented performance from the industry leader in landfill technology.
The Caron Double Semi-U Trashblade helps make your crawler an even more versatile and efficient machine.
The unique design of the blade forces refuse away from the center of the machine - directly into the path of the tracks where it can be more readily compacted in fewer passes.
A Straight Blade places materials with an even lift thickness under and between the tracks.
On a U-Blade, material flows to the center of the dozer, between the tracks resulting in less compaction.
The Caron Double Semi-U Blade collects materials in two separate sections under the tracks for maximum compaction performance.
http://www.caroncompactor.com
Fri, Apr 8, 2016 11:43 PM
