Found Starter parts for helical cut flywheel
Ace Flyguy
Send a private message to Ace Flyguy
Guys thru alot of playtime on the internet and getting paid for it at work, I found the correct gear for the 50/40MT starters and the nose housings, Both are available when I called the company. They need to be bought thru a legit business they will not sell to a individual.
The company is AEROHEAD ELECTRICAL PRODUCTS 1-800-328-5454.
My starter rebuild guys did not believe me until I proved to them that the parts did in fact truly exist.
I will now have a modern 50MT starter with the correct meshing gear.
[attachment=60919]SDR5090 starter rh gear cat 12.PNG[/attachment] [attachment=60920]SDR2011 nose housing Cat 12 starter.PNG[/attachment]
Keep the iron running
JP
Wed, Oct 28, 2020 12:46 PM
hfdzl
Good deal. I will put this info in my Cat archives!
Thu, Oct 29, 2020 4:00 PM
Thank you received: 52
Reply to hfdzl:
Be aware that housing only fits the early 40/50MT with flat flange gasket, not the later versions that use an o-ring seal.
Thu, Oct 29, 2020 10:32 PM
