Found a Crack is it a stress fracture or metal fatigue?
ncfarm
Send a private message to ncfarm
I dont mean to taking over with posts but I got some time to correct a few problems. When I took the larger cover plate on the rear housing off I found this crack in the front coner where the spring hanger attaches for brake petal. Haven't found the end yet. Just curious if its a major fix asap kind of problem. Cant post pic from phone will try later from computer. Thanks
Sun, Dec 18, 2016 12:12 AM
Thank you received: 50
Are you referring to the brake return spring anchor bolt with the crack radiating from the large cover plate opening to the bolt? If so that's probably a stress crack. Don't know that I'd get to excited about it, just make sure it's sealed up so that it doesn't become a water leak source. The housing is fabricated steel so welding it up would not be a big deal if you choose. Probably a good idea to find the end of the crack and stop drill it if it goes beyond the anchor bolt hole.
Sun, Dec 18, 2016 1:43 AM
