? for Old Magnet
? for Old Magnet
d42tjim
Send a private message to d42tjim
I was clearing some cedar trees on my place with my D-4 and I ran over some rocks on the side of the hill and broke a shackle on the Aux spring that holds the Equalizer spring in place( so it looks like) I found the Aux spring but the shackles are ruined--
? is this-- can i run this tractor this way or (and i know it needs to be fixed) do i stand to do more damage by not fixing it. Tractor appears to "ride ok on Eq spring"
Thanks Jim
Fri, Sep 19, 2008 6:07 AM
Thank you received: 46
Hi d42tjim,
Not a good idea to run without the auxiliary spring and shackles for a couple of reasons:
1. The auxiliary or rebound spring and shackles is all that holds the front end of the tractor down and can be a serious safety issue if it were to raise up and over.
2. The auxiliary spring needs to be in place and tensioned right (although most are not functioning properly) to keep the equalizer spring in place so that it doesn't flop around and accelerate the wear on the oil pan mounting resulting in a cracked and broken oil pan. This is not a good design to begin with and needs all the help it can get.
The shackles can be made from flat bar and it would be a good time to replace the pins and bushings. If the mounting pad on the pan is to worn to provide aux. spring tension you can shim with brass stock.
Fri, Sep 19, 2008 7:58 AM
d42tjim
Hi d42tjim,
Thanks Old Magnet
Will take your advice-- I took your advice on buying some service books on this tractor- but I bought from jensales and they are not very good( you did not recomend jensales) I wasted my money-my fault--- o well -live & learn and pay along the way. thats why I called you-about the springs- you shoot straight
Thanks again Jim
Sat, Sep 20, 2008 7:28 AM
